We have a 4 seat NLM license for ACAD 2015 and we rarely use all of them (until yesterday). The license server is controlled by out IT folks and I have no access to it. Is there a utility I can install on my local PC where the deployment was installed to find out who has the 4 seats checked out? I had to go person to person to find out who had the program open.
Solved by TravisNave. Go to Solution.
Have your IT install reporting tools (we use JTB) on the license server. Most of them can generate an HTML useage report which is refreshed at regular intervals.
If you go to the Server Status tab of LMTOOLS and click 'Perform Status Enquiry' it will tell you in real-time who has a license in use. If the license also says (LINGER) beside it then it means it is a borrowed license.
From the OP: "The license server is controlled by out IT folks and I have no access to it."
Running queries directly from LMTOOLS requires access. 🙂
I should have been more specific. You can run just the LMTOOLS utility from your computer and then configure it to get a server status from the server itself without having physical access to the server.
Run LMTOOLS. On the first tab Service/License File, choose Configuration using License File and then put 27000@SERVERNAME in the box. Servername will be the hostname of your NLM server.
Then go to the Server Status tab and click Perform Status Enquiry.
That will get you the real-time license status that you require.
Hope that helps!
Thanks for the answers. I don't think I have LMTOOLS installed but I have the original ACAD 2015 install disc. Can I install the first check box (Network License Manager) and get it? I don't want to mess up my deployment install.
Many thanks, it worked fine. My only observation/question is how do I make it bring up the servername after I close the utility? I put in my 27000@ servername and when I closed it and ran the utility again, the default was back to what it was before. Is there a way to save the servername or do I just
remember the server name?
Yeah, it reverts mine to default as well. I am not sure of a way to make it static, though you could essentially do the same with the LMUTIL.EXE command and execute a batch program for yourself to show a status in a command prompt.
If you set the ADSKFLEX_LICENSE_FILE system environment variable to your servername, though, you won't have to change it to 27000@servername because it will just pull the servername from the variable itself. Just do @servername in the value for that variable. I did test that and it works.
Good Luck!
Many Thanks. That worked and I don't have to remember ecdcgpappms03 is my server name.
The days of having to use system variables for programs was a long time ago for me in the DOS days when we had 8086 PC's and had to load high the things we needed to get on the Netware network, so we could use as much of the 640k ram as possible to run Lotus 123 spreadsheets.
