Getting Error 1609 when attempting to install AutoCAD LT 2014
Message 1 of 8
Getting Error 1609 when attempting to install AutoCAD LT 2014.  I have tried downloading the software from Autodesk Virtual agent.  The user account has local administrative rights to the machine.  Any help with this would be greatly appreciated.
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
Is the exact error:
""Error 1609: An error occurred while applying security settings"?
Windows OS? Server OS?
Read this other post:
http://forums.autodesk.com/t5/installation-licensing/auotcad-2012-error-1609-and-restricted-user/td-...
Message 3 of 8
The error is coming up when it has failed the Directx software.   The OS is Windows 7 64bit
Message 4 of 8
I have attached the Installation Log with the failed error
Message 5 of 8
Message 6 of 8
TravisNave
When you are installing, make sure you choose not to install the product with any updates or service packs.  I also see you are installing from a UNC path.  Have you tried copying the installation files locally and installing with local admin rights, UAC off, and antivirus disabled?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 7 of 8
Yes I have tried installing the software from the software CD on the computer logged in the local administrator.   I also downloaded full software package from the from the virtual agent website.  Yes I went into custom installation and unselected the service pack and updates. I get the same error over and over.
Message 8 of 8
TravisNave
Check your %TEMP% folder to see if there is a larger AutoCAD LT install log file that you can provide.
Autodesk Forums:
