Installation & Licensing
FLEXnet Licensing error:-125,147
29 REPLIES 29
Message 1 of 30
50530 Views, 29 Replies
Hello Support
I have problems connecting my Win7x64 Workstations to the new Win2008_R2 Licence server ( 3ds max 2011 )
i already read some of the posts here with same errors coeds
Server
running the licence server on an new ESX ( old license server is still running on an old ESX  in a Server2003x86 envirement )
(old hardware dont support win Server 2008 x64)
Server: WinS_2008_R2 x64 name: mum-108mgm
the ping to mum-108mgm is IPv4 (there was a IPv6 response so i deactivated the ip6 protocol and add the server to the hosts)
Configuration using Services
Ethernet adress in LMTOOLS: 000c294903b2
in MAXDES2011delicense.lic: SERVER mum-108mgm 000c294903b2
the License file was generated on the webside and send to me by email
i already tested an update to the flex LMTOOL v11.9 (same problems)
Server status output:
Status
Flexible License Manager status on Tue 11/23/2010 15:02
[Detecting lmgrd processes...]
License server status: 27000@mum-108mgm
    License file(s) on mum-108mgm: C:\Program Files (x86)\Autodesk Network License Manager\MAXDES2011delicense.lic:
mum-108mgm: license server UP (MASTER) v11.9
Vendor daemon status (on mum-108mgm):
  adskflex: UP v11.7
Feature usage info:
Users of 70100MAXDES_F:  (Total of 4 licenses issued;  Total of 0 licenses in use)
Users of 85503MAXDES_2011_0F:  (Total of 4 licenses issued;  Total of 0 licenses in use)
Users of 70000MAXDES_2010_0F:  (Total of 4 licenses issued;  Total of 0 licenses in use)
Users of 612003DSMAX_2009_0F:  (Total of 4 licenses issued;  Total of 0 licenses in use)
Users of 568003DSMAX_2008_0F:  (Total of 4 licenses issued;  Total of 0 licenses in use)
Perform Diagnostics output:
Diagnostics
FLEXnet diagnostics on Tue 11/23/2010 15:09
License file: C:\Program Files (x86)\Autodesk Network License Manager\MAXDES2011delicense.lic
license file(s):  C:\Program Files (x86)\Autodesk Network License Manager\MAXDES2011delicense.lic
"70100MAXDES_F" v2.000, vendor: adskflex
  License server: mum-108mgm
  floating license  starts: 1-jan-1990,  no expiration date
  Requests from the same USER/HOST do not consume a new license
This license cannot be checked out because:
A PACKAGE component must be specified.
Feature:       70100MAXDES_F
License path:  C:\Program Files (x86)\Autodesk Network License Manager\MAXDES2011delicense.lic;
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".
"85503MAXDES_2011_0F" v2.000, vendor: adskflex
This license can be checked out
"70000MAXDES_2010_0F" v2.000, vendor: adskflex
"612003DSMAX_2009_0F" v2.000, vendor: adskflex
"568003DSMAX_2008_0F" v2.000, vendor: adskflex
i already added a envirement variable: FLEXLM_DIAGNOSTICS value: 3
and get this error in a MsgBox from the MLTOOLS
Client
Windows 7 x64 (new installation)
i build a *network preinstallation* with x64 only components ( dont need the 3ds max 32bit part )
and installed this from a network share on the client
ping to server get IPv4
Envirement variables ADSKFLEX_LICENSE_FILE (@server) and FLEXLM_TIMEOUT (1000000) are already tested
i get all time the errors:
A valid license coud not be obtained by the network license manager.
If you still unable to access a license, contact your system administrator.
Error [0.0.0]
i klick Close then i get the Error:
The software license check out failed.
Error 20
hope i put all informations in here to help me 😉
best regards
Hello Support
Server
Status
  adskflex: UP v11.7
Feature usage info:
Diagnostics
Client
Error [0.0.0]
Error 20
best regards
29 REPLIES 29
Message 21 of 30
ruiz
in reply to: TravisNave
ruiz
Hola Travis,
Me sigue dando el mismo error hice un ping desde la work station al Server dond esta la licencia manager y esta Ok.
Desactive el Ipv6, cambie las variables de entorno, libere todo el firewall.
Todavia no puedo conseguir que funcione.
Desde ya te  agradezco tu ayuda para poder resolver esto.
Muchas gracias
Saludos
Hola Travis,
Muchas gracias
Saludos
Message 22 of 30
TravisNave
in reply to: ruiz
TravisNave
Intente comprobar los puertos con Internet Explorer.
http://servername:2080
http://servername:27000
Autodesk Forums:
Autodesk Forums:
Message 23 of 30
ruiz
ruiz
Hola,
Adjunto el error porque no me deja copiarlo aqui.
Gracias
Saludos
Hola,
Gracias
Saludos
Message 24 of 30
TravisNave
in reply to: ruiz
TravisNave
Lo siento, pero 27000, no 2700.
Autodesk Forums:
Autodesk Forums:
Message 25 of 30
ruiz
ruiz
Mil disculpas,
Me da esto: //sr05:27000/
Wê-60Wê-60Wê-60Wê-60Wê-60
Gracias por su tiempo.
Saludos
Mil disculpas,
Saludos
Message 26 of 30
TravisNave
in reply to: ruiz
TravisNave
Message 27 of 30
ruiz
ruiz
Yo instalé el servidor de licencia en un solo server como licencia unica en server.
Tengo que hacer esto?
Si lo tengo que hacer donde es que lo tengo que hacer en el Server o en el Workstation?
Saludos
Saludos
Message 28 of 30
ruiz
in reply to: ruiz
ruiz
Ya funciona. !!!!!!!!
Muchas gracias por todo
Message 29 of 30
TravisNave
in reply to: ruiz
TravisNave
De nada amigo!
Autodesk Forums:
De nada amigo!
Autodesk Forums:
Message 30 of 30
Try Disabling the Firewall on your Licensing Server. For me it worked.
Administrator Productivity
