Hello Support
I have problems connecting my Win7x64 Workstations to the new Win2008_R2 Licence server ( 3ds max 2011 )
i already read some of the posts here with same errors coeds
Server
running the licence server on an new ESX ( old license server is still running on an old ESX in a Server2003x86 envirement )
(old hardware dont support win Server 2008 x64)
Server: WinS_2008_R2 x64 name: mum-108mgm
the ping to mum-108mgm is IPv4 (there was a IPv6 response so i deactivated the ip6 protocol and add the server to the hosts)
Configuration using Services
Ethernet adress in LMTOOLS: 000c294903b2
in MAXDES2011delicense.lic: SERVER mum-108mgm 000c294903b2
the License file was generated on the webside and send to me by email
i already tested an update to the flex LMTOOL v11.9 (same problems)
Server status output:
Status
Flexible License Manager status on Tue 11/23/2010 15:02
[Detecting lmgrd processes...]
License server status: 27000@mum-108mgm
License file(s) on mum-108mgm: C:\Program Files (x86)\Autodesk Network License Manager\MAXDES2011delicense.lic:
mum-108mgm: license server UP (MASTER) v11.9
Vendor daemon status (on mum-108mgm):
adskflex: UP v11.7
Feature usage info:
Users of 70100MAXDES_F: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of 85503MAXDES_2011_0F: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of 70000MAXDES_2010_0F: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of 612003DSMAX_2009_0F: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of 568003DSMAX_2008_0F: (Total of 4 licenses issued; Total of 0 licenses in use)
Perform Diagnostics output:
Diagnostics
FLEXnet diagnostics on Tue 11/23/2010 15:09
License file: C:\Program Files (x86)\Autodesk Network License Manager\MAXDES2011delicense.lic
license file(s): C:\Program Files (x86)\Autodesk Network License Manager\MAXDES2011delicense.lic
"70100MAXDES_F" v2.000, vendor: adskflex
License server: mum-108mgm
floating license starts: 1-jan-1990, no expiration date
Requests from the same USER/HOST do not consume a new license
This license cannot be checked out because:
A PACKAGE component must be specified.
Feature: 70100MAXDES_F
License path: C:\Program Files (x86)\Autodesk Network License Manager\MAXDES2011delicense.lic;
FLEXnet Licensing error:-125,147
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".
"85503MAXDES_2011_0F" v2.000, vendor: adskflex
This license can be checked out
"70000MAXDES_2010_0F" v2.000, vendor: adskflex
"612003DSMAX_2009_0F" v2.000, vendor: adskflex
"568003DSMAX_2008_0F" v2.000, vendor: adskflex
i already added a envirement variable: FLEXLM_DIAGNOSTICS value: 3
and get this error in a MsgBox from the MLTOOLS
Client
Windows 7 x64 (new installation)
i build a *network preinstallation* with x64 only components ( dont need the 3ds max 32bit part )
and installed this from a network share on the client
ping to server get IPv4
Envirement variables ADSKFLEX_LICENSE_FILE (@server) and FLEXLM_TIMEOUT (1000000) are already tested
i get all time the errors:
A valid license coud not be obtained by the network license manager.
If you still unable to access a license, contact your system administrator.
Error [0.0.0]
i klick Close then i get the Error:
The software license check out failed.
Error 20
hope i put all informations in here to help me 😉
best regards
Solved by hashim.mundol. Go to Solution.
Please try the ipv6 patch on the server(it is not easy to get rid of all ipv6 components from windows 2008 server)
http://usa.autodesk.com/getdoc/id=DL10976858
with FLEXLM_DIAGNOSTICS = 3
you should have flex*.log in the application folder, please find the exact error in it.(or from the pop up window)
whats the result of
http://mum-108mgm:2080 from the client using Internet explorer.
also please post the relevant content of
%programdata%\Autodesk\Adlm\*adlm.log
hope you already tried to delete %programdata%\Autodesk\Adlm\cascadeinfo.cas, if not please try that too
hi
i installed/(replaced) the old files with the patch (http://usa.autodesk.com/getdoc/id=DL10976858)
the flex*.log output:
FLEXnet Licensing checkout error: A PACKAGE component must be specified.
available at "www.acresso.com".
output from http://mum-108mgm:2080 :
Wê-60Wê-60Wê-60Wê-60
also please post the relevant content of:
directory do's not exist
i only have a %programdata%\Autodesk\INSTALLER and a %programdata%\Autodesk\IMC3 dir
there is no dir and file 😮
im missing something there ? O.o how can i get it if i need it (create it manual ?)
best regards
hi
ok find the dir %programdata%\Autodesk\Adlm\ on the clients ... there is no cascadeinfo.cas file in there but a ProductInformation.pit and no logs @clients in %programdata%\Autodesk\Adlm\*adlm.log
best regards
following diagnostics error can be ignored.
"FLEXnet Licensing error:-125,147"
in the client
What about the flex*.log in the program's root folder when the diagnostics variable is created.
hi
@Client
added envirement variable : FLEXLM_DIAGNOSTICS value: 3
after reboot
still no log files but
some new error msg's (Attachments) and some more
+ error [0.0.0]
+ Error 20
Error 20
best regards
This error on client means there are no licenses available for this feature code. please check the server log for any similar error about feature not supported or no more licenses available.
you can check for these specific feature codes in the license status
85618AAAA_2011_0F
855013DSMAX_2011_0F
85617MXES_2011_0F
If the status you posted in the initial post is correct, your license is for
85503MAXDES_2011_0F->Autodesk 3ds Max Design 2011
and you have installed
855013DSMAX_2011_0F->Autodesk 3ds Max 2011
which would not work.
If you install Autodesk 3ds Max Design 2011 with correct product key (you received) the license should be taken.
License cascading is documented
http://usa.autodesk.com/getdoc/id=TS14885918
i redownloaded Autodesk 3ds Max Design 2011 + upgrades in the network deployment reinstalled the client again now it works just fine (-:
looking on the CD in the box i have a Autodesk 3ds Max Design 2011 CD O.o CD-key just worked with this ...
and i was searching serverside problem's ^^
thx for help
Quisiera solicitar ayuda para saber porque cada determinado tiempo el LMTOOLS no deja adquirir las licencias del servidor.Esto pasaba esporadicamente, pero ahora me pasa como 5 veces al día. El siguiente error es el que le sale a todos mis usarios, y lo único que hago es reiniciar el servicio desde el LMTOOLS.
Adjunto el archivo del error que me aparece. y la imagen que le aparece a mis usuarios.
espero me puedan ayudar gracias
Your -4 error means that you are out of licenses. There is probably not a problem with your License Manager. You simply need to have another user close out of the program so that you can open it.
Su error -4 significa que usted está fuera de licencias. Probablemente no hay un problema con su administrador de licencias. Usted sólo tendrá que tener otro usuario cierre el programa para que pueda abrirlo.
Gracias por la ayuda.
Otro problema que me pasa es que cuando cierro el programa se queda la licencia como en uso y no la libera, no sé a que se deba?
Esto es muy probablemente causado por el archivo exe de la aplicación. No soltarlo. Después de Task Manager cerrar, abrir y comprobar la aplicación en la pestaña Processes. Hasta que la aplicación se cierra completamente, la licencia no se libera.
Hola.
Tengo un problema con la instalacion por red con una suite de autodesk.
Instale la suite en una carpeta del Servidor como una imagen, despues instale la LMTOOLS Utility.
Fui a una Work station e instale desde el servidor la suite de Autodesk, cuando me sale activarla por Red, pongo el Nombre del Servidor y me sale: The software licence Check out failed, error 20.
En LMTOOLS Utility me da los siguientes errores.
Diagnostics
FLEXnet diagnostics on Fri 8/2/2013 17:05
License file: C:\Program Files\Autodesk\Autodesk Network License Manager\IDSP2014eslicense.lic
"85812IDSP_F" v1.000, vendor: adskflex
License server: sr05
Feature: 85812IDSP_F
License path: C:\Program Files\Autodesk\Autodesk Network License Manager\IDSP2014eslicense.lic;
"86123IDSP_2014_0F" v1.000, vendor: adskflex
"85992IDSP_2013_0F" v1.000, vendor: adskflex
"85799IDSP_2012_0F" v1.000, vendor: adskflex
"85882INFMDR_2012_0F" v1.000, vendor: adskflex
"85841ARDES_2012_0F" v1.000, vendor: adskflex
"85850MAP3DE_2012_0F" v1.000, vendor: adskflex
"85536ACD_2011_0F" v1.000, vendor: adskflex
"85601NAVSIM_2011_0F" v1.000, vendor: adskflex
"85557MAP_2011_0F" v1.000, vendor: adskflex
"85559TOPOBSCLNT_2011_0F" v1.000, vendor: adskflex
"85503MAXDES_2011_0F" v1.000, vendor: adskflex
"85604CIV3D_2011_0F" v1.000, vendor: adskflex
"85583LDXSP_2011_0F" v1.000, vendor: adskflex
"85683ARDES_2011_0F" v1.000, vendor: adskflex
tatus
Flexible License Manager status on Fri 8/2/2013 17:04
License server status: 27000@sr05
License file(s) on sr05: C:\Program Files\Autodesk\Autodesk Network License Manager\IDSP2014eslicense.lic:
sr05: license server UP (MASTER) v11.11
Vendor daemon status (on sr05):
adskflex: UP v11.11
Feature usage info:
Users of 85812IDSP_F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 86123IDSP_2014_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85992IDSP_2013_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85799IDSP_2012_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85882INFMDR_2012_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85841ARDES_2012_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85850MAP3DE_2012_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85536ACD_2011_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85601NAVSIM_2011_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85557MAP_2011_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85559TOPOBSCLNT_2011_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85503MAXDES_2011_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85604CIV3D_2011_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85583LDXSP_2011_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85683ARDES_2011_0F: (Total of 1 license issued; Total of 0 licenses in use)
Muchas gracias y espero sus respuestas
Bienvenidos,
-125 Los errores se pueden ignorar. Su LMTOOLS ve bien.
Pon una captura de error en el equipo cliente, por favor.
Gracias.
Hola,
Gracias por la respuesta.
Adjunto las capturas.
Saludos
Hola,
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7574782&linkID=9240617
Hola,
Hice todos los pasos en la work station, puse el valor de 10000000 y luego el de 1000000.
Me sigue dando el mismo error.
Es una red con dominio, con Windows 8 R2. la carpeta donde esta la licencia y la carpeta donde esta la suite como imagen estan compartida con los todos los permisos a full.
Necesito ayuda porque no podemos usar el programa.
Gracias
Saludos
Ahhh...
y
http://forums.autodesk.com/t5/Installation-Licensing/Autodesk-Network-License-Manager-2014/m-p/38199...
Buenos suerte.
