I opened Revit after a while and it said my license had expired. I renewed it using the link provided, I then reopened Revit and the same message popped up. I uninstalled and reinstalled, same message. I unassigned my email and reassigned my email, same message. I have tried uninstalling it and reinstalling it many times now but its all just the same. Please help!
Solved by jf006889. Go to Solution.
Reinstalling does nothing to the licensing of the software. So reinstalling over and over will just introduce extra problems that you do not have. You might need to do a license reset.
Hi @jf006889
Thanks a lot for posting your question to the forums! Have the solutions suggested by @rkmcswain @TravisNave helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Thanks for the replies. Interestingly, installing the older version on the 2024 Revit worked and didn't display the license expired message. Not sure how this works.
