Error 0.0.0
Error 0.0.0
Message 1 of 14
Error 0.0.0
Hello, have a bit of a problem.
What i did:
removed licence manager and installed newes. Entered all details, started server, checked it, got log like so:
Status
Flexible License Manager status on Wed 2/22/2017 13:46
[Detecting lmgrd processes...]
License server status: 27000@neo-rapp
License file(s) on neo-rapp: C:\Autodesk\Network License Manager\neo-rapp00505691E48A.lic:
neo-rapp: license server UP (MASTER) v11.13.1
Vendor daemon status (on neo-rapp):
adskflex: UP v11.13.1
Feature usage info:
Users of 86604ACD_2017_0F: (Total of 1 license issued; Total of 0 licenses in use)
The log file says:
13:32:52 (lmgrd) -----------------------------------------------
13:32:52 (lmgrd) Please Note:
13:32:52 (lmgrd)
13:32:52 (lmgrd) This log is intended for debug purposes only.
13:32:52 (lmgrd) In order to capture accurate license
13:32:52 (lmgrd) usage data into an organized repository,
13:32:52 (lmgrd) please enable report logging. Use Flexera Software LLC's
13:32:52 (lmgrd) software license administration solution,
13:32:52 (lmgrd) FlexNet Manager, to readily gain visibility
13:32:52 (lmgrd) into license usage data and to create
13:32:52 (lmgrd) insightful reports on critical information like
13:32:52 (lmgrd) license availability and usage. FlexNet Manager
13:32:52 (lmgrd) can be fully automated to run these reports on
13:32:52 (lmgrd) schedule and can be used to track license
13:32:52 (lmgrd) servers and usage across a heterogeneous
13:32:52 (lmgrd) network of servers including Windows NT, Linux
13:32:52 (lmgrd) and UNIX. Contact Flexera Software LLC at
13:32:52 (lmgrd) www.flexerasoftware.com for more details on how to
13:32:52 (lmgrd) obtain an evaluation copy of FlexNet Manager
13:32:52 (lmgrd) for your enterprise.
13:32:52 (lmgrd)
13:32:52 (lmgrd)
13:32:52 (lmgrd)
13:32:52 (lmgrd) Server's System Date and Time: Wed Feb 22 2017 13:32:52 FLE Standard Time
13:32:52 (lmgrd) pid 3520
13:32:52 (lmgrd) SLOG: Summary LOG statistics is enabled.
13:32:52 (lmgrd) Detecting other license server manager (lmgrd) processes...
13:32:52 (lmgrd) Done rereading
13:32:52 (lmgrd) FlexNet Licensing (v11.13.1.2 build 173302 x64_n6) started on neo-rapp (IBM PC) (2/22/2017)
13:32:52 (lmgrd) Copyright (c) 1988-2015 Flexera Software LLC. All Rights Reserved.
13:32:52 (lmgrd) World Wide Web: http://www.flexerasoftware.com
13:32:52 (lmgrd) License file(s): C:\Autodesk\Network License Manager\neo-rapp00505691E48A.lic
13:32:52 (lmgrd) lmgrd tcp-port 27000
13:32:52 (lmgrd) (@lmgrd-SLOG@) ===============================================
13:32:52 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
13:32:52 (lmgrd) (@lmgrd-SLOG@) Start-Date: Wed Feb 22 2017 13:32:52 FLE Standard Time
13:32:52 (lmgrd) (@lmgrd-SLOG@) PID: 3520
13:32:52 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.13.1.2 build 173302 x64_n6 ( build 173302 (ipv6))
13:32:52 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
13:32:52 (lmgrd) (@lmgrd-SLOG@) Listening port: 27000
13:32:52 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
13:32:52 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: Yes
13:32:52 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
13:32:52 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c C:\Autodesk\Network License Manager\neo-rapp00505691E48A.lic -l C:\Autodesk\Network License Manager\Logs\AutodeskNLM.log.txt -z -s
13:32:52 (lmgrd) (@lmgrd-SLOG@) License file(s) used: C:\Autodesk\Network License Manager\neo-rapp00505691E48A.lic
13:32:52 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-1024
13:32:52 (lmgrd) Starting vendor daemons ...
13:32:52 (lmgrd) Starting vendor daemon at port 2080
13:32:52 (lmgrd) Using vendor daemon port 2080 specified in license file
13:32:52 (lmgrd) Started adskflex (pid 5900)
13:32:52 (adskflex) Unable to initialize access to trusted storage: 1
13:32:52 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
13:32:52 (adskflex) SLOG: Summary LOG statistics is enabled.
13:32:52 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
13:32:53 (adskflex) SLOG: VM Status: 1
13:32:53 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
13:32:53 (adskflex) Server started on neo-rapp for: 86604ACD_2017_0F
13:32:53 (adskflex) EXTERNAL FILTERS are OFF
13:32:53 (lmgrd) adskflex using TCP-port 2080
13:32:53 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
13:32:53 (adskflex) SLOG: TS update poll interval is 600 seconds.
13:32:53 (adskflex) SLOG: Activation borrow reclaim percentage is 0.
13:32:53 (adskflex) (@adskflex-SLOG@) ===============================================
13:32:53 (adskflex) (@adskflex-SLOG@) === Vendor Daemon ===
13:32:53 (adskflex) (@adskflex-SLOG@) Vendor daemon: adskflex
13:32:53 (adskflex) (@adskflex-SLOG@) Start-Date: Wed Feb 22 2017 13:32:53 FLE Standard Time
13:32:53 (adskflex) (@adskflex-SLOG@) PID: 5900
13:32:53 (adskflex) (@adskflex-SLOG@) VD Version: v11.13.1.2 build 173302 x64_n6 ( build 173302 (ipv6))
13:32:53 (adskflex) (@adskflex-SLOG@) === Startup/Restart Info ===
13:32:53 (adskflex) (@adskflex-SLOG@) Options file used: None
13:32:53 (adskflex) (@adskflex-SLOG@) Is vendor daemon a CVD: No
13:32:53 (adskflex) (@adskflex-SLOG@) Is TS accessed: No
13:32:53 (adskflex) (@adskflex-SLOG@) TS accessed for feature load: -NA-
13:32:53 (adskflex) (@adskflex-SLOG@) Number of VD restarts since LS startup: 0
13:32:53 (adskflex) (@adskflex-SLOG@) === Network Info ===
13:32:53 (adskflex) (@adskflex-SLOG@) Listening port: 2080
13:32:53 (adskflex) (@adskflex-SLOG@) Daemon select timeout (in seconds): 1
13:32:53 (adskflex) (@adskflex-SLOG@) === Host Info ===
13:32:53 (adskflex) (@adskflex-SLOG@) Host used in license file: neo-rapp
13:32:53 (adskflex) (@adskflex-SLOG@) Running on Hypervisor: VMWare
13:32:53 (adskflex) (@adskflex-SLOG@) LMBIND needed: No
13:32:53 (adskflex) (@adskflex-SLOG@) LMBIND port: -NA-
13:46:30 (adskflex) TCP_NODELAY NOT enabled
I tried to remake lic file, entered name by host, by IP. Always same error when i try to start AutoCAD 2016. Could you help me solve it?
Because i have already used i think all solutions that found. Thank you.
BR,
Aleksandr
Replies (13)
Message 2 of 14
Mark.Lancaster
@Anonymous
Start >>here<<.  Check to make sure firewall is not blocking ports.  Good luck and report back on your progress
Mark Lancaster
Message 3 of 14
Users work locally on server, where AutoCAD is installed, so i doubt the ports are problems.
Disabled firewall, added port on incoming connection :
  • lmgrd.exe needs INCOMING TCP ports 27000 to 27009.
  • adskflex.exe needs 2080.
Also allow these .exe throught firewall. Same problem.
Message 4 of 14
Mark.Lancaster
@Anonymous
Is this a Citrix Environment?  If not this is not supported by the license manager and/or Autodesk.   Meaning you are unable to run a network version of an Autodesk application on a server.
Mark Lancaster
Message 5 of 14
No, this is not Citrix Enviroment. Server 2012R2, which is licence server.
Why do you mean we cannot use it, and how we did it untill few days ago, somebody, changed IP on this server? After that, this thing started to happen.
I requested new lic file, with new IP address. Users connect by RemoteAPP, that starting only AutoCAD application.
Now we have to install AutoCAD application on users PC and forward it to look licence on this server?
BR,
Aleksandr
Message 6 of 14
Mark.Lancaster
@Anonymous
Sorry if my message was unclear..  Meaning I was thinking this configuration its against Autodesk Licensing agreement but let me tag @scott_baker for his input.  Granted it may have worked but it also may go against the licensing aspect.
Mark Lancaster
Message 7 of 14
Hm.. I wonder why it can be against regulations? I mean it is still network licence and only one user at a time can use AutoCAD.
I think there is no difference, if AutoCAD is installed on one PC(server) and licence PC (server) on another or both things work from one PC (server).
Same licence conditions are applied. For this condition, only one user can work with software, another can only inform another users, that he wants to work with software.
BR,
Aleksandr
Message 8 of 14
Mark.Lancaster
@Anonymous
It may be fine..  There's conflicting messages/articles that I came across regarding this matter.  Let's wait to confirm what Scott has to say.  Meaning you want to make sure you are complaint..  Smiley Wink
Mark Lancaster
Message 9 of 14
**This is a post by scott.baker.  Working to resolve why it showed up under this name.
Provided the solution is not hosted off-premise, this should be fine however may not be supported depending on the remote solution being used.
Message 10 of 14
scott_baker
Please see previous response for comments.
Scott Baker
Automation & Licensing
Message 11 of 14
Could you explain a bit more, what should i do, for users to be able to use software again.
Message 12 of 14
scott_baker
I was previously only referring to the legality of running it on the server.  From a technical perspective, trying setting the ADSKFLEX_LICENSE_FILE environment variable to the loopback adapter address (@127.0.0.1) of the server using the information in the article below.
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-specify-license-s...
Scott Baker
Message 13 of 14
TravisNave
You are trying to launch AutoCAD 2016, but your license file only has 2017.  Are you not under Subscription with a Subscription license that allows 2016, 2015, and 2014?  I don't see them listed in the debug log.  Verify in your actual license file.  Otherwise download and install AutoCAD 2017.
86604ACD_2017_0F <-- AutoCAD 2017
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 14 of 14
That was actually the problem, overlooked it. Checked licence and saw, that now, we have licence for 2017 version and not 2016.
Downloaded 2017 and all started working.
Thank you for help.
BR,
Aleksandr
