- Mute
- Permalink
- Report
Hello, have a bit of a problem.
What i did:
removed licence manager and installed newes. Entered all details, started server, checked it, got log like so:
Status
Flexible License Manager status on Wed 2/22/2017 13:46
[Detecting lmgrd processes...]
License server status: 27000@neo-rapp
License file(s) on neo-rapp: C:\Autodesk\Network License Manager\neo-rapp00505691E48A.lic:
neo-rapp: license server UP (MASTER) v11.13.1
Vendor daemon status (on neo-rapp):
adskflex: UP v11.13.1
Feature usage info:
Users of 86604ACD_2017_0F: (Total of 1 license issued; Total of 0 licenses in use)
The log file says:
13:32:52 (lmgrd) -----------------------------------------------
13:32:52 (lmgrd) Please Note:
13:32:52 (lmgrd)
13:32:52 (lmgrd) This log is intended for debug purposes only.
13:32:52 (lmgrd) In order to capture accurate license
13:32:52 (lmgrd) usage data into an organized repository,
13:32:52 (lmgrd) please enable report logging. Use Flexera Software LLC's
13:32:52 (lmgrd) software license administration solution,
13:32:52 (lmgrd) FlexNet Manager, to readily gain visibility
13:32:52 (lmgrd) into license usage data and to create
13:32:52 (lmgrd) insightful reports on critical information like
13:32:52 (lmgrd) license availability and usage. FlexNet Manager
13:32:52 (lmgrd) can be fully automated to run these reports on
13:32:52 (lmgrd) schedule and can be used to track license
13:32:52 (lmgrd) servers and usage across a heterogeneous
13:32:52 (lmgrd) network of servers including Windows NT, Linux
13:32:52 (lmgrd) and UNIX. Contact Flexera Software LLC at
13:32:52 (lmgrd) www.flexerasoftware.com for more details on how to
13:32:52 (lmgrd) obtain an evaluation copy of FlexNet Manager
13:32:52 (lmgrd) for your enterprise.
13:32:52 (lmgrd)
13:32:52 (lmgrd)
13:32:52 (lmgrd)
13:32:52 (lmgrd) Server's System Date and Time: Wed Feb 22 2017 13:32:52 FLE Standard Time
13:32:52 (lmgrd) pid 3520
13:32:52 (lmgrd) SLOG: Summary LOG statistics is enabled.
13:32:52 (lmgrd) Detecting other license server manager (lmgrd) processes...
13:32:52 (lmgrd) Done rereading
13:32:52 (lmgrd) FlexNet Licensing (v11.13.1.2 build 173302 x64_n6) started on neo-rapp (IBM PC) (2/22/2017)
13:32:52 (lmgrd) Copyright (c) 1988-2015 Flexera Software LLC. All Rights Reserved.
13:32:52 (lmgrd) World Wide Web: http://www.flexerasoftware.com
13:32:52 (lmgrd) License file(s): C:\Autodesk\Network License Manager\neo-rapp00505691E48A.lic
13:32:52 (lmgrd) lmgrd tcp-port 27000
13:32:52 (lmgrd) (@lmgrd-SLOG@) ===============================================
13:32:52 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
13:32:52 (lmgrd) (@lmgrd-SLOG@) Start-Date: Wed Feb 22 2017 13:32:52 FLE Standard Time
13:32:52 (lmgrd) (@lmgrd-SLOG@) PID: 3520
13:32:52 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.13.1.2 build 173302 x64_n6 ( build 173302 (ipv6))
13:32:52 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
13:32:52 (lmgrd) (@lmgrd-SLOG@) Listening port: 27000
13:32:52 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
13:32:52 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: Yes
13:32:52 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
13:32:52 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c C:\Autodesk\Network License Manager\neo-rapp00505691E48A.lic -l C:\Autodesk\Network License Manager\Logs\AutodeskNLM.log.txt -z -s
13:32:52 (lmgrd) (@lmgrd-SLOG@) License file(s) used: C:\Autodesk\Network License Manager\neo-rapp00505691E48A.lic
13:32:52 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-1024
13:32:52 (lmgrd) Starting vendor daemons ...
13:32:52 (lmgrd) Starting vendor daemon at port 2080
13:32:52 (lmgrd) Using vendor daemon port 2080 specified in license file
13:32:52 (lmgrd) Started adskflex (pid 5900)
13:32:52 (adskflex) Unable to initialize access to trusted storage: 1
13:32:52 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
13:32:52 (adskflex) SLOG: Summary LOG statistics is enabled.
13:32:52 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
13:32:53 (adskflex) SLOG: VM Status: 1
13:32:53 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
13:32:53 (adskflex) Server started on neo-rapp for: 86604ACD_2017_0F
13:32:53 (adskflex) EXTERNAL FILTERS are OFF
13:32:53 (lmgrd) adskflex using TCP-port 2080
13:32:53 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
13:32:53 (adskflex) SLOG: TS update poll interval is 600 seconds.
13:32:53 (adskflex) SLOG: Activation borrow reclaim percentage is 0.
13:32:53 (adskflex) (@adskflex-SLOG@) ===============================================
13:32:53 (adskflex) (@adskflex-SLOG@) === Vendor Daemon ===
13:32:53 (adskflex) (@adskflex-SLOG@) Vendor daemon: adskflex
13:32:53 (adskflex) (@adskflex-SLOG@) Start-Date: Wed Feb 22 2017 13:32:53 FLE Standard Time
13:32:53 (adskflex) (@adskflex-SLOG@) PID: 5900
13:32:53 (adskflex) (@adskflex-SLOG@) VD Version: v11.13.1.2 build 173302 x64_n6 ( build 173302 (ipv6))
13:32:53 (adskflex) (@adskflex-SLOG@) === Startup/Restart Info ===
13:32:53 (adskflex) (@adskflex-SLOG@) Options file used: None
13:32:53 (adskflex) (@adskflex-SLOG@) Is vendor daemon a CVD: No
13:32:53 (adskflex) (@adskflex-SLOG@) Is TS accessed: No
13:32:53 (adskflex) (@adskflex-SLOG@) TS accessed for feature load: -NA-
13:32:53 (adskflex) (@adskflex-SLOG@) Number of VD restarts since LS startup: 0
13:32:53 (adskflex) (@adskflex-SLOG@) === Network Info ===
13:32:53 (adskflex) (@adskflex-SLOG@) Listening port: 2080
13:32:53 (adskflex) (@adskflex-SLOG@) Daemon select timeout (in seconds): 1
13:32:53 (adskflex) (@adskflex-SLOG@) === Host Info ===
13:32:53 (adskflex) (@adskflex-SLOG@) Host used in license file: neo-rapp
13:32:53 (adskflex) (@adskflex-SLOG@) Running on Hypervisor: VMWare
13:32:53 (adskflex) (@adskflex-SLOG@) LMBIND needed: No
13:32:53 (adskflex) (@adskflex-SLOG@) LMBIND port: -NA-
13:46:30 (adskflex) TCP_NODELAY NOT enabled
I tried to remake lic file, entered name by host, by IP. Always same error when i try to start AutoCAD 2016. Could you help me solve it?
Because i have already used i think all solutions that found. Thank you.
BR,
Aleksandr
