Installation & Licensing
Civil 3D install and uninstall HELP!
12 REPLIES 12
Message 1 of 13
2705 Views, 12 Replies
I installed C3D 2010 it wouldn't start and said it was missing some dll files. I tried to install again and and it wouldn't let me select to install C3D. I tried to uninstall, but it said the same error as trying to run it. It was missing a dll file. How can I uninstall this thing so I can re-install it now??????? HELP!!!!!!!!!! IT won't let me install over the existing installation and I can't uninstall because it is missing some dll?????
12 REPLIES 12
Message 2 of 13
DouglasLauritsen
What is the error message for the missing .dll file(s)? What is the result of trying a repair install from Add and Remove Programs? Is the error message the same? Can you provide Screen Shots? If you have more than one you can imbed them into a word file or .zip and post to this thread.
Douglas Lauritsen, Autodesk Product Support
Edited by: DouglasLauritsen on Apr 19, 2010 10:50 AM
Douglas Lauritsen
Support Specialist
Product Support
Autodesk, Inc.
Message 3 of 13
It doesn't show up in the add/ remove programs? The dll files I started to add manually from the installation directory, but it is missing several. I d/l'd this from the trial here. My best guess is it didn't locate the second file properly during my install? I don't know how to change the registry so the install program thinks there is no C3D on the machine.
Message 4 of 13
DouglasLauritsen
Do either of these registry keys exists?
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\7D2F387500089040002000060BECB6AB
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\7D2F387500089040012000060BECB6AB
Douglas Lauritsen
Support Specialist
Product Support
Autodesk, Inc.
Message 5 of 13
yes they are both there.
Message 6 of 13
correction the first one is. Not the second entry!
Message 7 of 13
DouglasLauritsen
Right-click on 7D2F387500089040002000060BECB6AB in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\7D2F387500089040002000060BECB6AB
and choose Export.
Once it is backed up, and not before, delete it then try the installer again.
When the export completes and you have Civil 3D installed and operating again you can delete the .reg file.
We appreciate your quick feedback on this forum!
Douglas Lauritsen
Support Specialist
Product Support
Autodesk, Inc.
Message 8 of 13
It looked like all was well.... but then it failed and here is the log.
=== Verbose logging started: 5/14/2010 13:55:15 Build type: SHIP UNICODE 4.05.6001.00 Calling process: C:\DOCUME~1\Angel\LOCALS~1\Temp\_AI1CE.tmp\setup.exe ===
MSI (c) (CC:80) [13:55:15:171]: Resetting cached policy values
MSI (c) (CC:80) [13:55:15:171]: Machine policy value 'Debug' is 0
MSI (c) (CC:80) [13:55:15:171]: ******* RunEngine:
******* Product: C:\Autodesk\AutoCAD Civil 3D 2010\x86\C3D\C3D.msi
******* Action:
******* CommandLine: **********
MSI (c) (CC:80) [13:55:15:171]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (CC:80) [13:55:18:171]: Failed to grab execution mutex. System error 258.
MSI (c) (CC:80) [13:55:18:171]: Cloaking enabled.
MSI (c) (CC:80) [13:55:18:171]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (CC:80) [13:55:18:171]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (F0:64) [13:55:18:187]: Running installation inside multi-package transaction C:\Autodesk\AutoCAD Civil 3D 2010\x86\C3D\C3D.msi
MSI (s) (F0:64) [13:55:18:187]: Grabbed execution mutex.
MSI (s) (F0:A8) [13:55:18:187]: Resetting cached policy values
MSI (s) (F0:A8) [13:55:18:187]: Machine policy value 'Debug' is 0
MSI (s) (F0:A8) [13:55:18:187]: ******* RunEngine:
******* Action:
MSI (s) (F0:A8) [13:55:18:187]: Machine policy value 'TransformsSecure' is 0
MSI (s) (F0:A8) [13:55:18:187]: User policy value 'TransformsAtSource' is 0
MSI (s) (F0:A8) [13:55:18:187]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (F0:A8) [13:55:18:187]: Specified instance {5783F2D7-8000-0409-0002-0060B0CE6BBA} via transform C:\DOCUME~1\Angel\LOCALS~1\Temp\_AI1CE.tmp\C3D\C3D-standalone.mst is already installed. MSINEWINSTANCE requires a new instance that is not installed.
MSI (s) (F0:A8) [13:55:18:187]: MainEngineThread is returning 1639
MSI (s) (F0:64) [13:55:18:187]: User policy value 'DisableRollback' is 0
MSI (s) (F0:64) [13:55:18:187]: Machine policy value 'DisableRollback' is 0
MSI (s) (F0:64) [13:55:18:187]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (F0:64) [13:55:18:187]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (F0:64) [13:55:18:203]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\InProgress 3: 2
MSI (s) (F0:64) [13:55:18:203]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (F0:64) [13:55:18:203]: Restoring environment variables
MSI (c) (CC:80) [13:55:18:203]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (CC:80) [13:55:18:203]: MainEngineThread is returning 1639
=== Verbose logging stopped: 5/14/2010 13:55:18 ===
here is the setup log
2010/5/14:13:01:21 Angel A-CFFB9AD0FD7F4 === Setup ended ===
2010/5/14:13:45:51 Angel A-CFFB9AD0FD7F4 === Setup started on A-CFFB9AD0FD7F4 by Angel ===
2010/5/14:13:46:07 Angel A-CFFB9AD0FD7F4 === Setup started on A-CFFB9AD0FD7F4 by Angel ===
2010/5/14:13:46:20 Angel A-CFFB9AD0FD7F4 === Setup ended ===
2010/5/14:13:54:42 Angel A-CFFB9AD0FD7F4 Install DirectX 9.0 Runtime Succeeded
2010/5/14:13:55:13 Angel A-CFFB9AD0FD7F4 Install Microsoft Visual Basic Power Packs 3.0 Succeeded
2010/5/14:13:55:18 Angel A-CFFB9AD0FD7F4 Install AutoCAD Civil 3D 2010 Failed Installation aborted, Result=1639
2010/5/14:13:58:32 Angel A-CFFB9AD0FD7F4 === Setup ended ===
Message 9 of 13
DouglasLauritsen
Can you post the .log files that were written to the user's temp folder? The information you posted indicates it would be here C:\DOCUME~1\Angel\LOCALS~1\Temp\. But to be sure you can type %temp% in the Windows Explorer address bar or in Start > Run. There should be several so please zip them up and post the .zip as you can only upload a single file per message. This way you don't have to post many messages to the thread.
Douglas Lauritsen
Support Specialist
Product Support
Autodesk, Inc.
Message 10 of 13
TravisNave
A 1639 error is an invalid command line argument. Are you installing this via a script, GPO, or some other modification? Also, are you installing a service pack at the same time? There seems to be a problem with the installation method here.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 11 of 13
surecad
OK, so what happened next....? How did you resolve the issue??
Message 12 of 13
joostweijers
I have exactly the same problem..
what to do? Smiley Sad
Tags (1)
Message 13 of 13
joostweijers
Kick!
Administrator Productivity
