Can I use two versions of Maya in the same computer as a single-user student?
SauloSatoshi
Message 1 of 11
SauloSatoshi
Hello, I'm a 3D animation student. I have Maya 2015 (single-user student) installed in my home computer. Recently I was having problems with a rig character so I decided to use Maya 2016/2017 to test if the problems would remain. I downloaded Maya 2016 as a single-user student and installed it. The software opens just fine. But when I do a pose with the character using Maya 2016 and I scrub the timeline, the character's pose comes back to the initial pose. So I can't animate the character anymore using Maya 2016. I uninstall Maya 2016 and install Maya 2016. And the same is also happening with Maya 2017. I didn't uninstall Maya 2015 of my computer. Is this happening because I can't download more than one version of Maya as a student user? Or maybe because I didn't uninstall Maya 2015? Does anyone have a clue why this is happening?
Replies (10)
Message 2 of 11
Otto
Hello saulosatoshi and welcome to the Autodesk community!
It looks like you need help uninstalling - or have issues that may be addressed by uninstalling - an Autodesk product. Community members with similar questions found the following article(s) useful: The following article(s) should help you resolve the problem:
Uninstalling a Product
Once your product is uninstalled, please try downloading your Autodesk Software using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 11
TravisNave
I cannot tell you why it is happening, but I can assure you that it has absolutely nothing to do with how many versions of Maya you have installed.  You can have all 3 versions installed without them interfering with each other.  The problem you are facing must be due to another factor.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 4 of 11
SauloSatoshi
Thanks Travis! I really appreciate your answer.
Message 5 of 11
dembkod
saulosatoshi
Hello. Yes, not likely an installation issue. I would suggest posting the query on the Maya forum. They should be able to help more directly with functionality questions:
https://forums.autodesk.com/t5/maya/ct-p/area-c2
Thank you for taking part in our community!
David Dembkoski
Message 6 of 11
SauloSatoshi
Thanks David. I will do that.
Message 7 of 11
SauloSatoshi
Problem solved. I didn't select 'auto key' under 'preferences>settings>animation'. ¬¬
Message 8 of 11
I did ask a question some days a go about different versions of Maya and plug-ins problem. Till now nobody has responded, but I found your tips very cool. now I can install 2 versions of Maya to see which one is more compatible for my works. Thank you so much
Message 9 of 11
SauloSatoshi
Hello Ali
You're welcome!
I'm glad my post and all the answers other members gave to help me also helped you.
I'm sure someone will answer your question soon.
Thanks Ali!
Message 10 of 11
i have maya 2020 but maya 2018 and 2019 not woriking for me error coming but i try to install maya 2015 but its say you can have one version . Unistall later version to install it why is that?
Regards
Ashik
Message 11 of 11
leowarren34
Hi @Anonymous,
Is this for a student license? Student licenses are only available back to the 2018 versions.
What OS are you running?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
