Hello. I recently installed AutoCAD 2015 and the message "unable to initialize adlm" keeps popping up and then Autocad crashes. I attached the errors below. I looked up some solutions and some forums said I have to delete some files under C:\ProgramData\FLEXnet but I couldn't find any flexnet folders under C:\ProgramData 😞 I could really use some help, thank you!
Solved by Mark.Lancaster. Go to Solution.
faithify
Welcome to the community...
I'm wondering if you have an incomplete installation, have you ran a repair on your AutoCAD 2015 installation? What is your operating system? I'm also tagging @TravisNave to see if he has any other ideas.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Thanks for the replies. I installed Autocad 2014 from this pc before and it seems I haven't completely uninstalled it and now I can't do proper installation of Autocad 2015. I reformatted my pc and everything works fine 🙂
I havre a problem: I lost the adskflex_00691b00_tsf.data.
I don’t know what I must do to recover it.
I wll appreciate your help.
thank you,
