A recent upgrade to AutoCAD Mechanical 2023 has created an unwanted side effect. When I am working in any drawing, my computer starts running hot, fans going all the time. From what I can tell, the source of this is Windows Defender Antivirus Service. I have noticed that it will use up whatever available CPU is left, causing the computer to run very hot, and a little slower.
I cannot simply turn off this service, as it's managed by the company.
All drawings are created by me; hosted on either our network server, or in ProjectWise.
I am looking for any solutions, any verification that this is an isse (as then, I may be able to make a case to have it disabled), or anything else anyone has to offer.
Solved by TravisNave. Go to Solution.
My guess is that it is probably working overtime on files that you are using over the network. I would have your IT make an exception for your Autodesk products or the shared network location for where the drawings are stored.
Good Luck!
Thanks! I tried a few other network folders and found that I was not having the same issue with drawings in those folders. I've chalked it up to something wrong in the creation of my specific network folder. I created a new one, copied everything over and I'm having no issues at this point.
Appreciate the comment; it certainly got the issue resolved!
