AutoCAD and Revit 2014 2015 2016 Unexpectedly closed FATAL ERROR at launch
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Windows 7 Ultimate 64 bit (updated to SP1), ASUS G750JW (GeForce GTX765M), UEFI mode, dual boot w/ Ubuntu, SSD
I have standalone subscription licenses for the Collection including AutoCAD and Revit 2017 back down to 2014 - purchased through local regional Autodesk vendor
Problem: each product throws a FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 6b82694bh (the last number will vary)
Note: this happens only AFTER activation; activation has been confirmed for each
Note2: Revit and AutoCAD 2015 and 2016 WORK CORRECTLY IN TRIAL MODE; the crash occurs only subsequent to activation. 2014 doesn't offer the trial mode.
Note3: Although each product has been activated, attempting to launch with internet connection turned off yields the 'Establish an internet connection to continue. The Autodesk license server cannot be...' error popup. Understandable if the products hadn't yet been activated
Note4: I'm pretty sure I uninstalled Internet Explorer (presumably the v10 that was built-in with windows install) since I use only Chrome and Firefox
Note5: this is a fresh machine
Note6: AutoCAD 2017 works correctly
Solutions attempted:
- reinstallation of Autodesk products
- re-download and reinstallation of Autodesk products
- download using Install Now / Download / Browser Download options where available
- full Autodesk manual uninstallation and reinstallation
- checking FlexNet service running
- wiping adlm flex files from license folder to force reactivation
- updated graphic drivers
- ran Windows updates
- running with /nohardware switch
- un-checked Internet Explorer 11 in Windows Features
- uninstall and re-install of Windows C++ runtime 2005-2012
- uninstall of .NET 4.6.1 down to 4.0, attempt to run @ 4.0, 4.5, 4.5.1; 4.6.1 then reinstalled
- note: BIOS does not offer option to disable the GTX. The ASUS machines automatically remove the System Agent options from the BIOS menuL
- killing LMU.exe process
- applying the installerR7 and R9 POODLE hotfixes for 2014 and 2015 (both ran successfully, without effect)
- enabling SSL3
- confirmed that I'm signed in under the Autodesk app / Application Manager
- Run as Adminstrator
- rubbing my belly and patting my head
I understand the GTX765M is not officially supported (as opposed to Quadra), but 2015 and 2016 products DID operate successfully in trial mode. They still do sometimes, in fact, because they appear to forget their successful activations.
