Installation & Licensing
ganesh.tiruvanmiyur.ext
555 Views, 2 Replies
AutoCad 2024
Hi Team,
This is Ganesh.    We are planning to upgrade/migrate from Current AutoCad 2021 to AutoCad 2024 Software .   In this regard we have the few clarification related to support of the Software.     Could you please share the following information:-
a) Please share compatibility matrix for Autocad 2024 for supporting OS
b) Please share the compatibility matrix for Autocad 2024 for .Net Framework
c) Please share the compatibility matrix for Autocad 2024 for Object ARX Version
d) Whether the Autocad 2024 is Compatible to run on cloud Azure OS
e) Which all  older versions of Autocad drawings are supported by Autocad 2024
f) Please share the official copy of Autocad 2021 to 2024 upgrade/migration guidelines document.
g) Pre-requisite hardware for Autocad 2024.
Tags (1)
2 REPLIES 2
The system requirements for AutoCAD 2024 are listed below:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/System-requirement...
a) 64-bit Microsoft® Windows® 11 and Windows 10 version 1809 or above
b) .NET Framework version 4.8 or later
c) For ObjectARX® for AutoCAD® 2024, 2023, 2022, and 2021
d) You can install AutoCAD on Windows in Azure Cloud
e)  AutoCAD 2024 uses the AutoCAD 2018 DWG format and can save backwards to R14
f)  Migration Guidelines can be found here
g) Hardware requirements are linked above.  Certified Graphics hardware can be found here
Hope that gets you started.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
system requirements are here: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/System-requirement...
this will answer a, d,g
for f: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-migrate-set...
for dwg versions Autocad 2024 didn't change from 2021
DarrenP
Administrator Productivity
