Why do I need to install "Inventor Interoperability 2024"?
jmarzbani
Message 1 of 15
jmarzbani
I recently upgraded my AutoCAD 2023 to AutoCAD 2024. Now, each time I open AutoCAD I see the following:
And when I click on "Install" this is what happens:
My questions are:
  1. Why do I need to install this?
  2. How do I install it? Why it fails every time?
Replies (14)
Message 2 of 15
WeTanks
Prease Update Inventor
Go to the Autodesk Accounts page or the Autodesk Desktop App and make sure that the latest update is applied.
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
Message 3 of 15
RobDraw
The message tells you why.
Rob
Message 4 of 15
mdavis22569
@WeTanks   It's 2024 and came out 2 days ago, there are no updates yet
Mike Davis
Message 5 of 15
mdavis22569
Prior screen do you have a check box to unclick?
Mike Davis
Message 6 of 15
TravisNave
See if you can download and install it manually.  Maybe it will give you a better reason as to why it is failing, if it does.
https://up1.autodesk.com/2024/INVSVR/D8A2B0D8-BCEC-3328-99A7-251C6A92ECD5/INVINTEROP_2024.exe
Good Luck!
Autodesk Forums:
Message 7 of 15
sti2d1_coliniere
Community Visitor
Community Visitor
Same problem , error while installing inventor interoperbility 2024 ,with autodesk destokp or manually
Message 8 of 15
dsummersPEG
No, there is no indication as to why this is needed. I just started seeing this too, and have no need for it. I am not about to install more bloated, buggy Autodesk software to cover up issues previous versions did not have. There is no check box to stop this irritating pop-up from reappearing every time I open files tainted by this issue. I have even deleted and purged everything from the file, and still the message appears.
Message 9 of 15
Supa_Designer
I see a different Error message.
I have installed Inventor 2023 and Vault Professional 2023.
Message 10 of 15
dsummersPEG
Tip: if you use msconfig and disable the Autodesk Access service, that pop-up still appears, but then disappears after wards. I was getting annoyed with notifications for updates, and disabled Autodesk Access on the msconfig Services and Startup tabs, and subsequently noticed the Inventor Interoperability pop-up disappeared on it's own shortly after it showed up. You might try uninstalling Autodesk Access, but I left it installed just in case.
Message 11 of 15
ahmed_kurdi_a
same problem,
before it was working correctly, now while using IW2024 showing this massage after opening the model.
Message 12 of 15
thiagohfdasilva
Community Visitor
Community Visitor
Obrigado, me salvou.
Message 13 of 15
Wheelie22
acad 2025 - i dont want - inventor interoperability 2025 component required
Message 14 of 15
Wheelie22
please go away - demand load
