What is file when install Revit ?
nuttpanu
nuttpanu
Can i delete this? Save for still working.
mdavis22569
I wouldn't delete it .. but move it to a 2nd drive or network location.
When you update you'll likely need some of those files
Mike Davis
nuttpanu
my store almost full. T-T
mdavis22569
You can delete it ...but as mentioned you might need it when updating your Revit .. there are some required MSI's
Mike Davis
TravisNave
Move it to a USB drive then.  Otherwise you will have to redownload the software if you want to reinstall/repair.
Autodesk Forums:
mdavis22569
That's the issue if you don't have the extra space ..
Having to download and extract it time an update comes out that needs something from the installer
Mike Davis
