VMware fusion & autodesk license on mac
I have got Windows 8 via VMware Fusion on my Mac. I can not install Inventor 2016 because I do not run 64 bit. When I try to install Inventor 2015 32 bit on the virtual machine I get the following message:
“You are attempting to install on an Operating System that is not supported.
Install on Windows 7 (32 bit or 64 bit) or Windows 8 (64 bit) for full support of all functionality.”
So is it possible for me to install Inventor on the virtual machine in any way?
Otto
Hello 239175 and welcome to the Autodesk community!
It looks like you need to find out more about downloading or re-downloading software, or are having issues that may be resolved by re-downloading.
For Windows users, before downloading products on Windows 10, please check that the product is compatible.
For general information about downloading or re-downloading (including eligibility), Community members with similar questions found the following article(s) useful:
Download Finder
Previous Versions of Autodesk Software
Download Methods
Find Your Eligibility for Previous Versions of Autodesk Software
Oftentimes installation and/or download issues can be addressed by using a different download method, or by downloading directly from the Autodesk Virtual Agent. Community members with similar issues found the following article(s) useful:
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
sureshchotrani
Wellcome to the community:)
Minimum requirement to install Inventor is list here, which clearly says you require 64bit operating system.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Thank you for welcoming me 🙂
Yes, it says so for the 2016 version but I am trying to install the 2015 version. There it says:
Minimum:
32-bit Microsoft Windows 7 (SP1)
I thought it also ment minimum Windows 7 but I think it means that it only works on Windows 7.
TravisNave
Is your Windows 7 updated to SP1?
Autodesk Forums:
