- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Issue: In previous versions of Autodesk products (except for Revit) it was not easily possible to switch license types from network to stand-alone without making registry changes or reinstalling the product entirely.
Solution: Autodesk has finally made switching from network to stand-alone and back much easier. In fact, you can switch from network to trial in the event that you find yourself off the network without a borrowed license. In a pinch, you could switch to a one-time trial install for 30 days and continue to work until you can access your network licensing again!
Instructions: Follow these steps to change your license type:
1. Launch your Autodesk 2017 product and choose the Help > About pulldown from the upper right-hand corner where the help ? bubble is located.
2. Choose the new Manage License... button (formerly Product Information) on the resulting window.
3. Under the new License Manager screen, choose the option for Change license type next to your installed product. Note the change that this is also the location where you borrow a network license.
4. Verify that you want to change the license type by clicking the Change button on the resulting window.
5. If you are on a network version, you may get the familiar warning to save and quit since your network license has now been removed. Choose the option that best fits your needs and let your Autodesk product close.
6. Launch your Autodesk product again. You will now be presented with the licensing screen just as if you installed it fresh. Choose the option that best fits your needs. If you are on a network version and do not have access to your network license manager because you forgot to borrow, then you can run a 30-day trial for one time only. A trial will only work once and cannot be reset.
Conclusion: Your product licensing can now be safely changed. Thank you Autodesk for finally addressing this issue over the years.
Good Luck!
Travis Nave
