SSO error, block users unless they are specifically granted ('assigned') access to the application.
e_derooy
e_derooy
Hi, today is decided to move to SSO for our company, so i folowed the tutorial, no big problems there it's quite clear but when i want to test the SSO connection i get the error stated below.
I tried two different users both parts of the only group and both have access to to AutoCAD LT.
Autodesk SSO for XXXXXXXX
U kunt niet worden aangemeld.
AADSTS50105: Your administrator has configured the application Autodesk SSO for XXXXXXXX ('XXXXXXXX-XXXX-XXXX-XXXX-XXXXX67e6229') to block users unless they are specifically granted ('assigned') access to the application. The signed in user 'EXXXXX@XXXXXXX.com' is blocked because they are not a direct member of a group with access, nor had access directly assigned by an administrator. Please contact your administrator to assign access to this application.
Meer informatie over probleemoplossing
Als u contact met uw beheerder opneemt, stuurt u deze informatie mee.
Informatie naar klembord kopiëren
Request Id: 154a848e-c5f6-4e03-b654-99dd7777c300
Correlation Id: cdcd4614-8f5d-47c1-9267-f29cb238da67
Timestamp: 2023-06-07T12:47:39Z
Message: AADSTS50105: Your administrator has configured the application Autodesk SSO for XXXXXXXX ('XXXXXXXX-XXXX-XXXX-XXXXXXXXXX67e6229') to block users unless they are specifically granted ('assigned') access to the application. The signed in user 'EXXXXX@XXXXXXX.com' is blocked because they are not a direct member of a group with access, nor had access directly assigned by an administrator. Please contact your administrator to assign access to this application.
Aanmeldingsfouten voor controle markeren: Markering inschakelen
Als u hulp nodig hebt bij het oplossen van dit probleem, schakelt u markeren in en probeert u de fout binnen twintig minuten te reproduceren. Met gemarkeerde gebeurtenissen worden diagnoses beschikbaar gemaakt en worden deze geactiveerd voor de beheerder.
  • SSO
e_derooy
Found the solution, not quite clear in the AutoDesk SSO installation guide, but i needed to add users in to the Azure Autodesk group not on the Autodesk website, so now it works. 😁
Microsoft Azure > Autodesk SSO for..... > Users and Groups > Add User > Users "press the blue text None selected"
Then select the users you wish to add to the Azure Autodesk SSO group.
TravisNave
Correct.  You have to add the users to the Autodesk SSO enterprise application within the Azure admin center.
Autodesk SSOAutodesk SSO
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
