Install AutoCAD 2023/2024 from local source rather than a network share
j.a.verslootC97EV
j.a.verslootC97EV
Dear AutoDesk,
We are a school and installing Autocad 2020 in the past from a local source, but the new versions 2023/2024 the installer seems different. We would like to deploy it from a local source and not from a network share(this method are fine in the nineties) but not in these days anymore.
Also we use a single license server NLM.
Can you help us with this please.
thank you
DarrenP
Not quite sure what you mean by a local share & a network share
A network share can be a local share that's inside your network
Are you looking for the offline installers?
DarrenP
systeembeheerF8E59
Observer
Observer
Hi, thank you. i didn't say "local share" but local source. but maybe i'm looking for a offline installer if that's the word 😉
GunnarNilsson
When i choose download in my portal I get a 15 MB file Create_Installer_ACD_2024_English_WIN64.exe. Executing that file crates a full installer in C:\Users\<username>\Downloads\Autodesk\AutoCAD 2024 - (EN)
TravisNave
Just go grab the full offline installers from this thread and share it on a network resource.  After installation, just point them to your NLM, or create a .reg file that already has the ADSKFLEX_LICENSE_FILE pointed to your existing NLM.  My 2024 Reset Tool has that option built in, if you wanna check that out in my signature.
https://forums.autodesk.com/t5/installation-licensing/2024-product-download-links/td-p/11835996
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
vladimir_ridner
Community Visitor
Community Visitor
Hello, The access to the links is denied, can you please reshare it with accessable links?
