Announcements
Revit Hotfix 2022.1.2 returning a server Error 1603
RevitOliver
RevitOliver
This Hotfix install whether from the Autodesk Desktop App from the complete list of products option; the hotfix installation falls over. This is a single education user licence, it can't be a server. Total mystery. Have uninstalled components and turned UAC off - no difference?
I am running as a an administrator.
Ray Georgiou
TravisNave
Are you experiencing the issue that the hotfix is supposed to address?  If not, then I would just recommend ignoring the hotfix.  There's no need to install a hotfix for a problem that you are not experiencing, as you will just create new problems for yourself... like this one.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Member1RayG
Dear Travis,
For me and my students Hotfix 2022.1.2 is necessary because NAVIATE REX Rebar extension installed with Naviate RE 2022 (64-bit).msi released September 2021 by Symetri; when installed into Revit without Hotfix 2022.1.2 will crash Revit 2022. It becomes impossible to run until Hotfix 2022.1.2 is uninstalled. I attach the install log
mdavis22569
@RevitOliver  were you able to resolve this?
Mike
Mike Davis
Member1RayG
I was not able to resolve this. I am not is a position to experiment, because my second installation on an alternative desktop which was running all Autodesk products perfectly (AutoCAD V22, Revit V22, Revit Hotfix 2022.1.2 , Naviate Rex and Robot Structural) was hit by a serious licensing error. Therefore I dare not experiment with the backup HPZ440 desktop PC.
