revit 2021 installation problom
husamcivil
husamcivil
I insalling revit 2021 and serial number will show (-sk) and cause activation code error 0015(22)
TravisNave
Try using my reset script for Autodesk 2021 products in my signature and redo the licensing to see if it will work for you.
Autodesk Forums:
