Revit 2017 Crash on Startup
L.Maas
Mentor Mentor
Message 1 of 33
L.Maas
One of our users has a problem with new installation of Revit 2017. It crashes on startup while still on the splashscreen with the message:
"Autodesk Revit 2017 has stopped working"
The journal (attached) gives some error messages. Unfortunately I can not find what the error is pointing at.
' 1:< DBG_WARN: failed to create message_queue named 'Session8072_P0MasterQueue' because boost::interprocess::intermodule_singleton initialization failed: line 203 of NOBLE\ManageWorkerServices.cpp.
' 1:< Exception occurred
'C 25-Apr-2016 17:45:32.367;   1:< ExceptionCode=0xc0000005 ExceptionFlags=0x00000000 ExceptionAddress=00007FFFF98C525B
I checked the System Requirement pages.
The user is running windows 10 Home 64 bit. Before investing in other windows version or new computer. So can I assume the cause is Windows 10 Home?
Louis
Please mention Revit version, especially when uploading Revit files.
Replies (32)
Message 2 of 33
Otto
Hello EnlInt
It looks like you are experiencing issues with your product on Windows 10 or want to know which Autodesk products are supported on Windows 10. Community members with similar questions found the following article(s) useful:
Windows 10 support for Autodesk products
Other threads about Windows 10 support
Change your mind about Windows 10? Here's how you can roll back
Please consider bookmarking these pages and checking back often; we'll update with new information as our testing continues.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 33
Darin.Green
Try replacing the Revit.ini with the out of box file. C:\ProgramData\Autodesk\RVT 2017\UserDataCache
If this information was helpful, please consider using the Accept Solution
Message 4 of 33
TravisNave
If that doesn't work, consider reinstalling the Universal C Runtimes.
https://www.microsoft.com/en-us/download/details.aspx?id=48234
Good Luck!
Autodesk Forums:
Message 5 of 33
L.Maas
Thanks for your inputs. Unfortunately problem is not resolved.
@Darin.Green Tried replacing the ini file. Unfortunatley, problem remains.
@TravisNave Looked at the Universal runtimes. Are you pointing me to the right files?
After downloading unpacked the zip file which contained the following files:
When trying to open several of those msu files it says:
"The update is not applicable to your computer"
For your information things I have already done:
-Redownloaded BDSU 2017 from Autodesk.
-Uninstalled all Autodesk software (including previous versions) followed THIS procedure from knowledge to get rid of leftovers
-Reinstalled Revit 2017, same issue.
-Reinstalled Revit 2016, working properly.
Louis
Message 6 of 33
Darin.Green
@L.Maas, If you right-click the Revit shortcut, do you see the flyout "Run with Graphics Processor"? If so, you'll need to disable optimus using the workflow outlined by @TravisNave. Also, update the graphics card to the latest version from the vendor website.
Message 7 of 33
L.Maas
@Darin.Green
No flyout "Run with Graphics Processor" avaialble.
The computer is not a laptop but a HP, small tower. Graphics card is a NVidea Geforce GTX 650 Ti, with the latest WHQL driver 364.72.
Plenty of free space on the drives.
Temp folder emptied recently.
Windows has the latest updates.
Revit 2016, also cleanly installed a few days ago is working in good order.
Another computer, still on Windows 7, also has a Geforce GTX 650 Ti, has no problem running Revit 2017.
Louis
Message 8 of 33
p2sjames
i am having the same problem on Windows 7.
When i double click Revit 2017 it say An Unrecoverable Error has Occured... and closes 😞
'C 05-May-2016 08:29:39.177; 0:< ExceptionCode=0xc06d007f ExceptionFlags=0x00000000 ExceptionAddress=000007FEFD0E965D
' 0:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 0:< RAM Statistics: 13017 / 32705 145=InUse 146=Peak
' 0:< VM Statistics: 8388058 / 8388607 70=InUse 71=Peak
' 0:< Unconverted MessageBox "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files."
scan2BIM - www.point2surveyors.com
Message 9 of 33
p2sjames
still have this problem, could it be related to having the 2017 beta installed?
when i install Revit, the splash screen says Revit K**p**r
Message 10 of 33
L.Maas
Your error seems to be different from my situation. I would advise to post your issue in a new thread.
Louis
Message 11 of 33
Getting a similar issue, but the error in the journal is different:
' 0:< Managed exception occurred:
'C 13-May-2016 11:05:04.565;   0:< Method not found: 'Void System.Runtime.InteropServices.Marshal.StructureToPtr(!!0, IntPtr, Boolean)'.
'C 13-May-2016 11:05:04.565;   0:< ExceptionCode=0xe0434352 ExceptionFlags=0x00000001 ExceptionAddress=000007FEFD20A06D
' 0:< RAM Statistics:    28142 /    32691       512=InUse      513=Peak
' 0:< VM  Statistics:  8384641 /  8388607       403=InUse      404=Peak
' 1:< ::1:: Delta VM: Avail +1 -> 8384641 MB, Used 403 MB; RAM: Avail +120 -> 28263 MB, Used 512 MB, Peak +0 -> 513 MB
' 1:< GUI Resource Usage GDI: Avail 9761, Used 239, User: Used 205
' 1:< Revit worker 1 closed cleanly
' 0:< [00000fec]QueueMinder stopped
So far we've replaced the revit.ini, doing a repair, and removing MS XML & onenote printers but so far unsuccessful.
We're going through the .NET system, doing all updates, and if that doesn't help we'll try a .NET repair https://support.microsoft.com/en-us/kb/2698555
If that doesn't help we'll do a reinstall next.
Edit to add: updating .NET completely and rebooting (required 3 reboots for all updates) corrected our issue.
Message 12 of 33
Hello i have the same error  on Windows 8.1 entreprise.
Here a log of the Windows events : (in french)
Nom de l’application défaillante Revit.exe, version : 17.0.416.0, horodatage : 0x56cf8ad9
Nom du module défaillant : RevitDB.dll, version : 17.0.416.0, horodatage : 0x56cf88ef
Code d’exception : 0xc0000005
Décalage d’erreur : 0x000000000050525b
ID du processus défaillant : 0x1f60
Heure de début de l’application défaillante : 0x01d1c2e4ff0080f6
Chemin d’accès de l’application défaillante : C:\Program Files\Autodesk\Revit 2017\Revit.exe
Chemin d’accès du module défaillant: C:\Program Files\Autodesk\Revit 2017\RevitDB.dll
ID de rapport : 3f657830-2ed8-11e6-82d0-acfdce251916
Nom complet du package défaillant :
ID de l’application relative au package défaillant :
Message 13 of 33
Darin.Green
Disable your antivirus application then try launching Revit again. This is a big issue with TrendMicro.
Message 14 of 33
Hello thanks for the quick reply, but i don't have Trend antivirus.
Message 15 of 33
RichardJenkins
Hi
Has anyone been able to solve this start up problem.
I installed Revit 2017 trial version on my office desktop (windows 7 pro) connected to a windows server, revit 2017 installed without any errors. When I click icon the splash screen shows and then after a few seconds it disappears. I did all the usual stuff (repair/ uninstall reinstall etc) but still does has the same issue. FYI, I installed the Revit 2017 trial version on my laptop at home (windows 10) and works just fine.
Message 16 of 33
JHeilman258
Just noticed this happening today. Splash screen would load for a few seconds then a notification that the application has stopped would pop up.
Repaired the Microsoft .NET framework 4.6.1, restarted and Revit 2017 is back up. Hope this helps.
Message 17 of 33
RichardJenkins
Hi, I repaired net framework and also updated to current version but still the same problem. I don't get an error message, splash screen just disappears. The journal file below: ' 0:< Initial VM: Avail 8388342 MB, Used 14 MB, Peak 14; RAM: Avail 4887 MB, Used 48 MB, Peak 14 ' 0:< GUI Resource Usage GDI: Avail 9995, Used 5, User: Used 3 'C 24-Jun-2016 14:12:06.728; 0:< started recording journal file ' Build: 20160225_1515(x64) ' Branch: RELEASE_2017_RTM Dim Jrn Set Jrn = CrsJournalScript 'C 24-Jun-2016 14:12:06.729; 0:< ->desktop InitApplication 'C 24-Jun-2016 14:12:06.735; 0:< <-desktop InitApplication 'C 24-Jun-2016 14:12:06.735; 0:< ->desktop InitNativeInstance ' 0:< Options::loadOptions: m_strDataLibraryLocations=Metric Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\Australia\,Metric Detail Library=C:\ProgramData\Autodesk\RVT 2017\Libraries\Australia\Detail Items (defaultLib==\Library) ' 0:< ::0:: Delta VM: Avail -37 -> 8388305 MB, Used +6 -> 20 MB, Peak +6 -> 20 MB; RAM: Avail -33 -> 4855 MB, Used +14 -> 62 MB, Peak +14 -> 62 MB ' 0:< GUI Resource Usage GDI: Avail 9979, Used 21, User: Used 25 'C 24-Jun-2016 14:12:07.235; 0:< License initialization complete ' 0:< License version: 17.3.26.0 ' 0:< ::0:: Delta VM: Avail -172 -> 8388133 MB, Used +31 -> 52 MB, Peak +34 -> 55 MB; RAM: Avail -72 -> 4783 MB, Used +49 -> 111 MB, Peak +49 -> 111 MB ' 0:< GUI Resource Usage GDI: Avail 9979, Used 21, User: Used 49 ' 0:< SystemSettings: ' 0:< 4=multiCoreCharacteristic ' 0:< true=isProcessUserModeExceptionPolicyDisabledForCallbackFilter ' 0:< ::0:: Delta VM: Avail -18 -> 8388116 MB, Used +8 -> 60 MB, Peak +5 -> 60 MB; RAM: Avail -16 -> 4768 MB, Used +15 -> 126 MB, Peak +15 -> 126 MB ' 0:< GUI Resource Usage GDI: Avail 9971, Used 29, User: Used 62 'C 24-Jun-2016 14:12:07.692; 0:< manage licensing ' 0:< ::0:: Delta VM: Avail -14 -> 8388103 MB, Used +1 -> 62 MB, Peak +1 -> 62 MB; RAM: Avail -52 -> 4716 MB, Used +2 -> 129 MB, Peak +4 -> 131 MB ' 0:< GUI Resource Usage GDI: Avail 9967, Used 33, User: Used 66 'C 24-Jun-2016 14:12:22.191; 0:< License checkout cancel by user 'C 24-Jun-2016 14:12:22.191; 0:< License cleanup skipped
Message 18 of 33
Darin.Green
Your profile is incomplete. Please try resetting your Revit profile by perform the following:
Navigate and delete the following directories:
  • C:\Users\<username>\AppData\Local\Autodesk\Revit\Autodesk Revit 2017
  • C:\Users\<username>\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2017
Open the registry editor (Start > Type REGEDIT hit enter)
Delete the following registry folder:
  • HKEY_CURRENT_USER\SOFTWARE\Autodesk\Revit\Autodesk Revit 2017
On those the deleted, launch Revit again.
Message 19 of 33
RichardJenkins
Hi Darin, first of all, thank you for post and help.
I tried exactly what you suggested, and Revit 2017 did the same thing, crashes when on splash screen, no warning or error message.
I also uninstalled Revit 2017 and reinstalled but still does the same.
The journal file is the same as I posted previously.
Any other ideas how to get this working.
Message 20 of 33
m_latz
Just read your post, and there was a similar problem in AutoCAD in the past.
There it was a problem with the CascadeInfo.cas file.
The file should located at C:\ProgramData\Autodesk\ADLM
Try to backup and then delete the file.
If you restart Revit the file should be recreated.
regards
Markus
