Revit 2015 - not able to install again after failed installation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello
I recently updated my Revit 2014 - 2015, When the installation was 6 of 7 steps done, an error occured saying i missed some files which resulted in Revit 2015 not functioning optimal. I then uninstalled it, and deleted all of my autodesk programs in control panel. redownloaded the program and tried to install it again. This time it said that Revit 2015 was already installed on my PC. I then manually tried to delete all files, but one file called RVT2015.mst cannot be deleted because it is running in a different program in the background. This is not the case, because I have no other programs running.
My student administration don't know the problem so no help from them. My next step is format c, but if you know the issue that would help alot.
