Problem with installing Revit 2025
aya_irshead
Message 1 of 9
aya_irshead
Community Visitor
Community Visitor
Hi guys,
I’m trying to install revit 2025, but when I tried the first time the downloading process froze at 97% for quite a long time, so I tried to delete it and download it again but my pc keeps telling me that I still got it.
- I deleted it from settings as will
- I still have revit 2023
Can you guys help me understand what’s wrong? And what to do about it?
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
@aya_irshead wrote:
Hi guys,
I’m trying to install revit 2025....
Try this direct 10+GB single installer file download instead
https://forums.autodesk.com/t5/installation-licensing/2025-product-download-links/m-p/12663620#M2776...
Message 3 of 9
mdavis22569
Can you try reviewing the following too:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Autodesk-Revit-202...
The key for Revit 2023 is
"{7346B4A0-2300-0510-0000-705C0D862004}"
Mike Davis
Message 4 of 9
four2una
Community Visitor
Community Visitor
Hi, I'm facing exactly the same problem- it got to 97% and stopped for 4 hours...Can you please tell me what did you do?
Message 5 of 9
mdavis22569
Hi @four2una
Did you try the direct download links in the 2025 folder?
Clean out the %temp% folder while they are downloading.
Mike Davis
Message 6 of 9
TravisNave
Let it run overnight if you have to.  It will complete, you just have to be patient.  Constantly cancelling the installer will only cause additional installation problems for you.
Autodesk Forums:
Message 7 of 9
engkahhat
Community Visitor
Community Visitor
Hi guys,
I’m trying to install Revit 2025, but when I am trying the installing process froze at 97% for quite a long time as 4-5 Hours. What I should I do, do you recommend stop/ cancelling installation. Please let me know.
Message 8 of 9
Simon_Weel
Indeed incredibly annoying. If you check the installation logs, you'll notice it's waiting for a pipe to do something that never happens. If the Cancel button is available, click it. And if you the get the warning 'Are you sure' or something like that, click Resume. Most of the times this will get the installer going again.
Message 9 of 9
terry2C7N2
Community Visitor
Community Visitor
This did the trick for me, haha. I had v4.3 stuck at 98% for about 20 minutes. Click 'Cancel', then 'Continue', and hop right to.
