problem licensing with LMTOOLS for 3DSMAX 2012
Message 1 of 12
hi, we are a small company with 4 employee and we recently moved our office, hired new people and etc...
i was not the one who first installed lmstools and the computer and now it look like it is now my job.
The one who did it was fired 3 years ago and it is impossible to contact him
for a new computer, i have to instal 3DSMAX 2012
we have a perpetual license
i used the tutorial on autodesk to make sure everything is set up and working fine on the server side
I tried both service mode and file mode and both of them work on server side.
for the user computer, when i press next after typing the server name i get this:
The flexnet license finder has completed. press finish...
so the communication with the server work but right after i get this:
A valid license could not be obtained by the network license manager
error -15.570.0
On the server side, when i do a Perform Status Enquiry
Status
Flexible License Manager status on Tue 12/22/2015 08:42
[Detecting lmgrd processes...]
License server status: 27000@SERVER
License file(s) on SERVER: C:\Program Files (x86)\Autodesk\Autodesk Network License Manager\License\3DSMAX2012frlicense.lic:
SERVER: license server UP (MASTER) v11.9
Vendor daemon status (on SERVER):
adskflex: UP v11.9
Feature usage info:
Users of 856983DSMAX_2012_0F: (Total of 1 license issued; Total of 0 licenses in use)
and with a perform diagnostic
Diagnostics
FLEXnet diagnostics on Mon 12/21/2015 15:49
License file: C:\Program Files (x86)\Autodesk\Autodesk Network License Manager\License\3DSMAX2012frlicense.lic
"856983DSMAX_2012_0F" v1.000, vendor: adskflex
License server: SERVER
floating license starts: 1-jan-1990, no expiration date
Requests from the same USER/HOST do not consume a new license
This license can be checked out
finally
FLEXnet Licensing v11.9.0.0 build 87342_i86_n3fff
I absolutly need to make this work by friday or it may cause us a really costly delay in our planning + all the time i have spent on that instead of programming
the lmtool is runned as administrator
the 3ds max was installed as administrator and is also opened as administrator for the licensing
Replies (11)
Message 2 of 12
Otto
Hello cedricraymond and welcome to the Autodesk community!
It looks like you are seeing "FLEXnet Licensing error:-15,570". The following article(s) should help you resolve the problem:
Common FlexNet error codes
How to specify license servers using the ADSKFLEX_LICENSE_FILE environment variable
Troubleshooting FLEXnet Licensing Errors
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 12
thanks for the quick answer
as i can see, error -15 means Cannot connect to license server system. The server (lmadmin or lmgrd) has not been started yet, or the wrong port@host or license file is being used, or the TCP/IP port or host name in the license file has been changed. Windows XP SP2 platforms have a limit on the number of TCP/IP connection attempts per second that can be made, which your application may have exceeded. Refer to the manufacturer's documentation on how to change this limit.
on the lmtools in the start/stop/reread tab, when i press start server it says: server start failed. The server may already be running!
So i assume it is working
The ReRead License File button return no error, only Reread server license file completed
when i try to execute the imgrd.exe as admin or not, i only get a blackbox popping really fast, i could see some text on it for a fraction of a second but i were not successfull in trying to make a screenshot
i am currently reading the whole licenseadministration.pdf in hope of finding a solution or where i have been wrong since i had to guess everything so far
Message 4 of 12
i found out the ports http://servername:27000 and http://servername:2080 were locked.
with the server manager i unlocked them.
it is still not working
the server have some shared folder and the computer i am trying to install 3dsmax have no problem connecting to it
Message 5 of 12
TravisNave
PING the server.  Make sure it gets the correct IPv4 address.  Do not use a IPv6 address or you will have to make some changes on the client.
Do the http://servername:27000 links work?  Do you get the jargon page?
Autodesk Forums:
Message 6 of 12
i finally managed to make it work
to make it short, every problem was there and most of them was caused by the bad setup of the ancient tech guy.
ipv6 was on, network was on public, flexnet had no reference for the lic file, the flexnet service was not on automatic, the server firewall and so on and so on....
thanks for all the solutions, i would say that every solution posted here was actually one of the many problem. this was a huge headache
Message 7 of 12
this thread should be kept since it make reference to all the possible problem someone could occur
Message 8 of 12
We just ran into a similar problem, but none of the solutions proposed above work.
We are a startup with an 8 user license running on a server since January with no issue until today. Today, with no changes other than Windows updates, it refuses to check out any licenses at all.
The 'FlexNet Licensing error:-125,147' error is mentioned here http://forums.autodesk.com/t5/installation-licensing/flexnet-licensing-error-125-147/td-p/2834003 but does not apply to this problem.
Both client and server can talk fine to eash other.
Diagnostics below
Diagnostics
FlexNet diagnostics on Mon 4/25/2016 12:10
License file: C:\Program Files\Autodesk Network License Manager\Licenses\3dsmax.lic
"662003DSMAX_F" v1.000, vendor: adskflex, expiry: 06-jan-2019
License server: ERU
floating license starts: 1-jan-1990, expires: 06-jan-2019
This license cannot be checked out because:
A PACKAGE component must be specified.
Feature: 662003DSMAX_F
License path: C:\Program Files\Autodesk Network License Manager\Licenses\3dsmax.lic;
For further information, refer to the FlexNet Licensing documentation,
available at "www.flexerasoftware.com".
"858923DSMAX_2013_0F" v1.000, vendor: adskflex, expiry: 06-jan-2019
License server: ERU
"85893MAXDES_2013_0F" v1.000, vendor: adskflex, expiry: 06-jan-2019
License server: ERU
"860803DSMAX_2014_0F" v1.000, vendor: adskflex, expiry: 06-jan-2019
License server: ERU
"86081MAXDES_2014_0F" v1.000, vendor: adskflex, expiry: 06-jan-2019
License server: ERU
"862623DSMAX_2015_0F" v1.000, vendor: adskflex, expiry: 06-jan-2019
License server: ERU
"86263MAXDES_2015_0F" v1.000, vendor: adskflex, expiry: 06-jan-2019
License server: ERU
"864713DSMAX_2016_0F" v1.000, vendor: adskflex, expiry: 06-jan-2019
License server: ERU
Message 9 of 12
I was copying the Max install locally to reinstall it, but it suddenly started working again for everyone.
Does FlexNet LM 'phone home' at all? It feels like something like this was happening - or not happening in this case. In the future, is there any way to check this?
Cheers
John
Message 10 of 12
TravisNave
There is no phone home.
Autodesk Forums:
Message 11 of 12
...this is still happening sporadically; we just have to wait 15 mins and try again. The best workaround seems to be to leave Max running as the license check is only done at startup.
The server can be pinged and it's running fine (I'm remoted in to it)
Cheers
John
Message 12 of 12
TravisNave
Are you using FLEXLM_TIMEOUT on the clients?
Autodesk Forums:
