Network license setup on client
Message 1 of 10
Dear all,
I spent a lot of time trying to figure out how to solve my problem, and finally decided to register here on your forum.
I would like to setup Network license.
I installed Network License Manager.
I requested a Network License File.
I configured the Network License Manager with the given Network License File for AutoCAD 2016.
Finally I start License server and everything seems fine on the server side.
My problem is - HOW TO CONFIGURE CLIENT TO CONTACT NETWORK LICENSE SERVER ?
I installed AutoCAD on my client machine.
I started AutoCAD. First the "Initializing" comes up. Then "Checking license".
Then additional windows comes up "Your Autodesk Trial".
If I go to "Activate now" of course it does not work beacuse I have serial key for network licensing.
If I go to "Continue Trial" then application is open.
But I cannot find anywhere in the AutoCAD the option to set the licensing server.
What do I exactly have to do on the client side ?
Replies (9)
Message 2 of 10
Otto
Hello hrvoje.lugaric and welcome to the Autodesk community!
It looks like you want information on how to install the Network License Manager. Community members with similar questions found the following article(s) useful:
Installing the Network License Manager on Windows
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 10
I'm waiting for a real reply. Because as I noted in the post, I already setup and install Network License Server, I have a problem how to configure the clients.
Message 4 of 10
rkmcswain
@Anonymous.lugaric - AutoCAD LT does not support network licensing.
If you decide to move to full AutoCAD, you can tell the client where to find the LM using a Windows Environment Variable, as described here.
R.K. McSwain     | CADpanacea | on twitter
Message 5 of 10
rkmcswain
Wrong again Otto.
Message 6 of 10
Sorry, typo - it's not LT. I corrected now my question, I don't know why I put LT in the text...Smiley Sad
Message 7 of 10
rkmcswain
See post 4 then.
Message 8 of 10
Ok, thanks. So the mistake was made during the installation procedure - another License Type had to be installed...
Message 9 of 10
Mark.Lancaster
@Anonymous
Based on your information, you installed the application as a standalone license.  You need to switch the registry entry as indicated here   Since this is an old article, just make sure to adjust the path in the registry for your version.  Then as @rkmcswain pointed out create the system variable.
Mark Lancaster
Message 10 of 10
TravisNave
If the reg switch doesn't work, which is hit or miss, then a reinstall will get it.  Fortunately, they have *finally* addressed this in 2017 and you can switch it in the license information help window.  If you are under Subscription, then you can get 2017 now.
Autodesk Forums:
