Managing the adskflex.opt Options File
TravisNave
Mentor Mentor
Message 1 of 83
TravisNave
Issue:  You want to configure different licensing options for different user groups and networked licensed products using your Autodesk Network License Manager.
Solution: There is a way to manually configure the Autodesk Network License Manager to use different configurations for each license type, user, group, etc.  You need to create an Options file as instructed in the License Administration Guide.  Your options file should be created in a plain text editor like Notepad and must be named adskflex.opt.  Please ensure that file extensions are enabled so that you do not have a hidden .txt file extension appended to your filename.  Furthermore, the adskflex.opt options file must be saved in the same location as your Autodesk .lic license file.  To activate the options file, you need to reread the license from the Start/Stop/Reread tab of LMTOOLS.  You can then use your debug.log file to verify that the options are working properly.
Additional information about the adskflex.opt Options File can be found here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7459915&linkID=9240617
Creating and Implementing the adskflex.opt Options File
1.  To create an options file, simply open a plain text editor like Notepad and type the options that you wish to implement.
2.  Make sure you then save the file as adskflex.opt and in the same location as your Autodesk *.lic file.  You will want to pull down the save type box to all files so that it will not save with a .txt extension.  Make sure file extensions are enabled to determine if a .txt has been appended. If so, simply rename the file as appropriate.
3.  Open LMTOOLS and go to the Start/Stop/Reread tab and choose ReRead License File.  This will enable the options file that you just saved.
4.  You can verify that the options file is active by viewing the debug.log file.  You can do this from the Config Services tab in LMTOOLS by clicking View Log... or by opening the debug.log file in Notepad from the path specified on the Config Services tab.  You should see log entries for each successful option that you created.  Entries should look similar to the following:
16:52:45 (adskflex) Using options file: "C:\Program Files\Autodesk Network License Manager\License\adskflex.opt"
16:52:45 (adskflex) ALL FEATURES: INACTIVITY TIMEOUT set to 900 seconds
16:52:45 (adskflex) Max borrow interval for feature, 64300ACD_F , set to 48 hours
16:52:45 (adskflex) RESERVING 1 64300ACD_F  license for USER_GROUP Admins
16:52:45 (adskflex) MAX 1 USER_GROUP Users for 64300ACD_F
16:52:45 (adskflex) INCLUDE USER_GROUP Admins 64300ACD_F
16:52:45 (adskflex) Report log started (+C:\Program Files\Autodesk Network License Manager\report.rl).
You can use the adskflex.opt options file to split licenses into different groups, reserve licenses for power users, or limit the amount and time licenses can be borrowed.  For details on each available option, please see the License Administration Guide in the documentation of your Autodesk Network License Manager or from the Autodesk KB link provided above.
Feature codes for each of your licensed products can be found within the PACKAGE and INCREMENT lines of the .lic license file provided by Autodesk.  A list of Autodesk 2012 feature codes can be found here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17288427&linkID=9243099
For your convenience I am attaching a ready-made adskflex.opt options file that includes all of the available compatible options for the Autodesk Network License Manager along with commented descriptions and examples. You can use this file as a starting point to create your own customizations.  Please unzip the file and edit with Notepad.
Good Luck!
Autodesk Forums:
Replies (82)
Message 2 of 83
TravisNave
The License Administration Guide for the FlexLM can be found at the following link:
http://www.globes.com/support/utilities/fnp_LicAdmin_11_9_1.pdf
Please see chapter 13 regarding the Options File.
Autodesk Forums:
Message 3 of 83
hi
having trouble with Building Design Suite 2013 and borrowing licences .... i have created an adskflex option file.
and have confirmed the option file is being read by lmtool/flexlm.
i am the only user id in the borrowcad group ; however other users are still able to borrow licences even tho they are not included in the group. Have i missed something ?
options file :-
#options file matt 02/04/2013
GROUP BorrowCad camsr1
TIMEOUTALL 900
# Building Design Suite Standard
BORROW_LOWWATER 85947BDSS_2013_0F 1
INCLUDE_BORROW 85947BDSS_2013_0F GROUP BorrowCad
#Building Design Suite Premium
BORROW_LOWWATER 85946BDSPRM_2013_0F 1
INCLUDE_BORROW 85946BDSPRM_2013_0F GROUP BorrowCad
Do i need to individually add all features codes in the suite ? and assign the BorrowCAD group?
any help appreciated
regards
Matt
Message 4 of 83
TravisNave
You need to add the option GROUPCASEINSENSITIVE ON to your list. That
should allow it to work.
Autodesk Forums:
Message 5 of 83
I have 8 license for Autodesk Product Desing Suite Standar 2014, but we just use the ACAD Mechanical 2011 (beacuse our standard)...
But we want to have 1 licenese reserved for a group of 2 users, and another license for another 2 users... the remaining 6 license wil be available for the rest of the users.
This is the option file so far:
GROUP Engineering jdelacru ichavez
GROUP ProductEng egarcia1 joliver
RESERVE 1 85813PDSS_F GROUP Engineering
RESERVE 1 85813PDSS_F GROUP ProductEng
But, at todays license usage, I notice that egarcia1 and joliver can have 2 license opened at the same time, is it possible to isolate this license just for one of them at the time? I mean, if egarcia1 has the ACAD open, then joliver has to wait until the license is released.
Another question is, the users only opens AutoCAD Mechanical 2011, is it correct to add this feature code only? 85813PDSS_F ?
How can I configure the rest of the users to look only for the 6 remaining license on the pool?
Thank you very much for the help!Smiley Happy
Message 6 of 83
TravisNave
Welcome to the community.
Excellent questions.  I believe what you are asking can be done with some tweaking.
You can limit the group to the 1 license by using the MAX option.  Here's what I recommend for your options file syntax:
TIMEOUTALL 900
MAX 1 85813PDSS_F GROUP Engineering
MAX 1 85813PDSS_F GROUP ProductEng
This would still reserve the 2 licenses (effectively leaving the 6 for everyone else *not* on the group list.)  But it would also limit the groups to 1 license max each.  So if egarcia1 is using AutoCADM, then joliver will get denied until that one reserve is freed up.  Nobody else would be denied unless the 6 remaining are used up.  I always recommend the TIMEOUTALL option because it will help return idle licenses should somebody launch the program and then leave it up all day and not use it.
Also, it might be a good idea to consider the EXCLUDE_BORROW option for those groups as well, because of egarcia1 borrows a seat, then joliver will never be able to launch it, until it expires.  Just a thought.
As for your feature code, it's best to reserve with the PDSS_F because it reserves the whole Subscription package, rather than just the Mechanical.  So, you're fine there.
Make the changes, stop/start the service, and verify in the debug.  Hope that helps!
Autodesk Forums:
Message 7 of 83
Is it possible to limit the max usage of one of the software titles within the Building Design Suite?  For example, in a 10-user network license, can AutoCAD be prevented from consuming more than 4 BDS network licenses?  Can it be done without having to define and maintain a group in the options file?
Thanks!
Message 8 of 83
TravisNave
This is a tough question.  You might be able to do it with a MAX option on your entire subnet.
MAX 4 86063ACD_2014_0F INTERNET 192.168.1.*
Limiting cascade is not any easy thing to do in partial.  It's typically all or none.  But you might be able to experiment and get something figured out.
Autodesk Forums:
Message 9 of 83
GTVic
Hi Travis,
Is it possible to break the HOST_GROUP <name> <computer1> <computer2> ... line into multiple lines?
Greg
Message 10 of 83
TravisNave
Yes, the line is infinite so wordwrap doesn't mean anything.
Autodesk Forums:
Message 11 of 83
TravisNave
Since the retirement of the FlexLM download site, I have been asked a few times for updated information.  Attached is the FlexLM User Guide (PDF) that is no longer valid at the link I provided.
Also, since the recent changes in the Autodesk support links, the original knowledge base link for the options file has been changed.  The new link can be found here:
http://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2014/ENU/Autodesk-Licensing/fil...
Hope this helps.
Autodesk Forums:
Message 12 of 83
jocelyn.mombo
Observer
Observer
Hi Travis,
We have an issue to run ours AutoCAD licenses.
Last year we got AutoCAD 2014 version and it working well, this year we get a AutoCAD 2015 version, so we have 2 licenses.
Now we want to run both AutoCAD 2014 & 2015 version on NetWork licensing way. But when a version is running we cannot run the another version it seem that the server don't see 2 licenses. We have 2 licenses but we cannot run the 2 licenses run simultanously we get error code erreur[-4.132.0]. see bellow your licenses and Option file, please someone can you tell what is wrong ?
License file
Please be aware that this is a public forum posting serial numbers or personal information is not advised
Edited by
Discussion_Admin
Message 13 of 83
TravisNave
License files only combine properly when they are generated on the same date.  So, therefore, in your case only the newer license is being recognized.  If you redo the license files today, you will see both seats.
Autodesk Forums:
Message 14 of 83
Can you group IP addresses the same way as you can with users
For example
GROUP EngineeringGroup 192.168.26.* 192.168.27.* 192.168.28.*
and still reserve the licenses by using
RESERVE 5 86268PDSU_2015_0F EngineeringGroup
Message 15 of 83
TravisNave
Unfortunately no.  The groups have to be usernames or hostnames.
To use the IP Addresses, you have to format it like this:
RESERVE 5 86268PDSU_2015_0F INTERNET 192.168.26.*
If you have multiple subnets, I suppose you can make multiple reserves.
Autodesk Forums:
Message 16 of 83
The down side of multiple reserves is when one site has more than one subnet eg
One of our sites uses 192.168.26.*, 192.168.27.* and 192.168.28.*
If I enter multiple lines does that not mean I am reserving 15 licenses (3 x 5) for that one site?
RESERVE 5 86268PDSU_2015_0F INTERNET 192.168.27.*
RESERVE 5 86268PDSU_2015_0F INTERNET 192.168.28.*
Message 17 of 83
Miquel
What I have to do, to exclude a time out user by product?
This way:
TIMEOUTALL 900
EXLUDE_TIMEOUT 85782INVPUB_F HOST xxxxxxx
or:
TIMEOUTALL 900
EXLUDE 85782INVPUB_F HOST xxxxxxx
Message 18 of 83
Travis,
I am writing a license options file for the first time. Does this look correct to you? Thank you for your time.
GROUP Machine_Shop user1 user2 user3
GROUP Manufacturing user4
RESERVE 2 86393INVHSM_F GROUP Machine_Shop
RESERVE 1 86249FDSPRM_2015_0F USER user4
Message 19 of 83
TravisNave
Yes. Looks good. Just keep in mind that your RESERVE on the 86393INVHSM_F
is your Subscription file so it might try to reserve all the previous
versions as well. This might cause you to reserve more licenses than you
own and prevent others from using the rest. Testing and looking at the
server status will verify.
Also, your second RESERVE is on a USER, which is fine, but you specified
the GROUP before it yet didn't use it.
Autodesk Forums:
Message 20 of 83
Travis,
Does this look better?
USER Manufacturing user4
