Ok It just happened again. This is the log.
9:33:57 (lmgrd) -----------------------------------------------
9:33:57 (lmgrd) Please Note:
9:33:57 (lmgrd)
9:33:57 (lmgrd) This log is intended for debug purposes only.
9:33:57 (lmgrd) In order to capture accurate license
9:33:57 (lmgrd) usage data into an organized repository,
9:33:57 (lmgrd) please enable report logging. Use Flexera Software LLC's
9:33:57 (lmgrd) software license administration solution,
9:33:57 (lmgrd) FlexNet Manager, to readily gain visibility
9:33:57 (lmgrd) into license usage data and to create
9:33:57 (lmgrd) insightful reports on critical information like
9:33:57 (lmgrd) license availability and usage. FlexNet Manager
9:33:57 (lmgrd) can be fully automated to run these reports on
9:33:57 (lmgrd) schedule and can be used to track license
9:33:57 (lmgrd) servers and usage across a heterogeneous
9:33:57 (lmgrd) network of servers including Windows NT, Linux
9:33:57 (lmgrd) and UNIX. Contact Flexera Software LLC at
9:33:57 (lmgrd) www.flexerasoftware.com for more details on how to
9:33:57 (lmgrd) obtain an evaluation copy of FlexNet Manager
9:33:57 (lmgrd) for your enterprise.
9:33:57 (lmgrd)
9:33:57 (lmgrd)
9:33:57 (lmgrd)
9:33:57 (lmgrd) Server's System Date and Time: Tue Mar 21 2017 09:33:57 Central Daylight Time
9:33:57 (lmgrd) pid 3332
9:33:57 (lmgrd) SLOG: Summary LOG statistics is enabled.
9:33:57 (lmgrd) Detecting other license server manager (lmgrd) processes...
9:33:57 (lmgrd) Done rereading
9:33:57 (lmgrd) FlexNet Licensing (v11.13.1.2 build 173302 x64_n6) started on ussppals100 (IBM PC) (3/21/2017)
9:33:57 (lmgrd) Copyright (c) 1988-2015 Flexera Software LLC. All Rights Reserved.
9:33:57 (lmgrd) World Wide Web: http://www.flexerasoftware.com
9:33:57 (lmgrd) License file(s): E:\Licensing\ussppals100005056A144C5.lic
9:33:57 (lmgrd) lmgrd tcp-port 27000
9:33:57 (lmgrd) (@lmgrd-SLOG@) ===============================================
9:33:57 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
9:33:57 (lmgrd) (@lmgrd-SLOG@) Start-Date: Tue Mar 21 2017 09:33:57 Central Daylight Time
9:33:57 (lmgrd) (@lmgrd-SLOG@) PID: 3332
9:33:57 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.13.1.2 build 173302 x64_n6 ( build 173302 (ipv6))
9:33:57 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
9:33:57 (lmgrd) (@lmgrd-SLOG@) Listening port: 27000
9:33:57 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
9:33:57 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: Yes
9:33:57 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
9:33:57 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c E:\Licensing\ussppals100005056A144C5.lic -l E:\Autodesk\Network License Manager\Logs\debug.log -z -s
9:33:57 (lmgrd) (@lmgrd-SLOG@) License file(s) used: E:\Licensing\ussppals100005056A144C5.lic
9:33:57 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-1024
9:33:57 (lmgrd) Starting vendor daemons ...
9:33:57 (lmgrd) Starting vendor daemon at port 2080
9:33:57 (lmgrd) Using vendor daemon port 2080 specified in license file
9:33:57 (lmgrd) Started adskflex (pid 3632)
9:33:57 (adskflex) Unable to initialize access to trusted storage: 1
9:33:57 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
9:33:57 (adskflex) SLOG: Summary LOG statistics is enabled.
9:33:57 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
9:33:57 (adskflex) SLOG: VM Status: 1
9:33:57 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
9:34:00 (adskflex) Server started on ussppals100 for:
9:34:00 (adskflex) 662003DSMAX_F (consisting of: 86081MAXDES_2014_0F
9:34:00 (adskflex) 866333DSMAX_2017_0F 864713DSMAX_2016_0F 862623DSMAX_2015_0F
9:34:00 (adskflex) 86263MAXDES_2015_0F 860803DSMAX_2014_0F)
9:34:00 (adskflex) 64300ACD_F (consisting of: 86604ACD_2017_0F
9:34:00 (adskflex) 86445ACD_2016_0F 86295ACD_2015_0F 86063ACD_2014_0F)
9:34:00 (adskflex) 65500ACAD_E_F (consisting of: 86635ACAD_E_2017_0F
9:34:00 (adskflex) 86481ACAD_E_2016_0F 86290ACAD_E_2015_0F 86150ACAD_E_2014_0F
9:34:00 (adskflex) 86149ECSCAD_2014_0F 86300ECSCAD_2014_1F)
9:34:00 (adskflex) 85622INVLTS_F (consisting of: 86746INVLTS_2017_0F
9:34:00 (adskflex) 86485INVLTS_2016_0F 86233INVLTS_2015_0F 86127INVLTS_2014_0F)
9:34:00 (adskflex) 86029SCFDA_F (consisting of: 86805SCFDA_2017_0F
9:34:00 (adskflex) 86541SCFDA_2016_0F 86337SCFDA_2015_0F 86142SCFDA_2014_0F)
9:34:00 (adskflex) 86035SCDSE_F (consisting of: 86806SCDSE_2017_0F
9:34:00 (adskflex) 86546SCDSE_2016_0F 86342SCDSE_2015_0F 86147SCDSE_2014_0F)
9:34:00 (adskflex) 86802PLC0000023_F (consisting of: 86802PLC0000023_2017_0F)
9:34:00 (adskflex) 85814PDSP_F (consisting of: 86690PDSP_2017_0F
9:34:00 (adskflex) 86477PDSP_2016_0F 86266PDSP_2015_0F 86132PDSS_2014_0F
9:34:00 (adskflex) 86081MAXDES_2014_0F 86172NAVSIM_2014_0F) 86544SCFDP_2016_0F
9:34:01 (adskflex) EXTERNAL FILTERS are OFF
9:34:01 (lmgrd) adskflex using TCP-port 2080
9:34:01 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
9:34:01 (adskflex) SLOG: TS update poll interval is 600 seconds.
9:34:01 (adskflex) SLOG: Activation borrow reclaim percentage is 0.
9:34:01 (adskflex) (@adskflex-SLOG@) ===============================================
9:34:01 (adskflex) (@adskflex-SLOG@) === Vendor Daemon ===
9:34:01 (adskflex) (@adskflex-SLOG@) Vendor daemon: adskflex
9:34:01 (adskflex) (@adskflex-SLOG@) Start-Date: Tue Mar 21 2017 09:34:01 Central Daylight Time
9:34:01 (adskflex) (@adskflex-SLOG@) PID: 3632
9:34:01 (adskflex) (@adskflex-SLOG@) VD Version: v11.13.1.2 build 173302 x64_n6 ( build 173302 (ipv6))
9:34:01 (adskflex) (@adskflex-SLOG@) === Startup/Restart Info ===
9:34:01 (adskflex) (@adskflex-SLOG@) Options file used: None
9:34:01 (adskflex) (@adskflex-SLOG@) Is vendor daemon a CVD: No
9:34:01 (adskflex) (@adskflex-SLOG@) Is TS accessed: No
9:34:01 (adskflex) (@adskflex-SLOG@) TS accessed for feature load: -NA-
9:34:01 (adskflex) (@adskflex-SLOG@) Number of VD restarts since LS startup: 0
9:34:01 (adskflex) (@adskflex-SLOG@) === Network Info ===
9:34:01 (adskflex) (@adskflex-SLOG@) Listening port: 2080
9:34:01 (adskflex) (@adskflex-SLOG@) Daemon select timeout (in seconds): 1
9:34:01 (adskflex) (@adskflex-SLOG@) === Host Info ===
9:34:01 (adskflex) (@adskflex-SLOG@) Host used in license file: ussppals100
9:34:01 (adskflex) (@adskflex-SLOG@) Running on Hypervisor: VMWare
9:34:01 (adskflex) (@adskflex-SLOG@) LMBIND needed: No
9:34:01 (adskflex) (@adskflex-SLOG@) LMBIND port: -NA-
9:34:01 (adskflex) TCP_NODELAY NOT enabled
9:34:01 (adskflex) OUT: "85814PDSP_F" youngj03@USMN-4Y43KC2-L
9:34:01 (adskflex) OUT: "86132PDSS_2014_0F" youngj03@USMN-4Y43KC2-L
12:37:14 (adskflex) IN: "86132PDSS_2014_0F" youngj03@USMN-4Y43KC2-L
12:37:14 (adskflex) IN: "85814PDSP_F" youngj03@USMN-4Y43KC2-L
12:38:15 (adskflex) OUT: "85814PDSP_F" youngj03@USMN-4Y43KC2-L
12:38:15 (adskflex) OUT: "86132PDSS_2014_0F" youngj03@USMN-4Y43KC2-L
