Invalid product key?
I have recently had to upgrade my own computer and transfer a new 2016 license to mine. I successfully de-activated their license using the license transfer utility but when I type in the serial code and Product key into mine I get an invalid product key error? I am using the correct key but it won't register.
Desperate help needed.
Many thanks,
Jack
Otto
Hello jack and welcome to the Autodesk community!
It looks like you're getting an "Invalid Serial Number” message or having trouble with your product key while trying to register and activate your Autodesk software. The following article(s) should help you resolve the problem:
Click Top reasons why you may get a Serial Number Error during Activation
And check Error: "Invalid serial number" (standalone activation)
For product key information: Finding Serial Numbers & Product Keys
If you’re having an issue with your product key, please make sure that you are using the correct one for your product (especially if your product comes from a suite). Finally, you should type then numbers and letters in. We do not recommend copy/paste.
If you are still having issues activating your product, you may visit our Activation Contact Us page and submit your inquiry there.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
TravisNave
Here is the list of 2016 product keys:
http://knowledge.autodesk.com/customer-service/installation-activation-licensing/get-ready/find-seri...
Make sure you are trying it in and not copy/paste.
Autodesk Forums:
sureshchotrani
Product Key are different for different suites, if you have AutoCAD with AutoCAD Design suite then product key will be different when compare to plain AutoCAD.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Thank you very much
my product key is 001H1 as it's written on the email, but it doesn't work...
I tried also with 781H1 but it doesn't work too.
Many thanks
Emiliano
Mark.Lancaster
@Anonymous
You need to indicate which Autodesk product or suite that you have and the version as well.  Each product and version has its own product key informaiton.
And welcome to the community and hopefully my (or someone else) reply will be beneficially to you.
As a reminder, this is a world wide (public) user forum where users are assisting others. In addition do not post, attach screen shots, or share any personal information (such as your serial #) here.
Mark Lancaster
