Installer: Not enough space on C, even when all temp folders are on D
Message 1 of 8
I have an SSD for my C drive which has less than 5GB free space and I cannot remove anything from it.
All my Temp folders are mapped to be on D drive, yet the installer would not start and still gives me an error saying that I do not have enough space on C. Why does it need 15GB on C drive when I am trying to install on D drive and all my temp folders are on D as well.
Even if the isntaller wants to use temo folders to unpack, this shouldn't be a problem as my temp folders are on D drive where I have 500+GB free space.
Does this mean that I simply cannot install 3dsMax 2016?
Replies (7)
Message 2 of 8
Message 3 of 8
I had already done all of those previously and I only have 7GB free space on my C drive. This is really frustrating that I have to have space on my C drive to install something on my D drive!
I need 15GB on my C drive to install 5GB on my D drive! it just makes no sense.
Message 4 of 8
TravisNave
If you move your temp file over to D:\ as well as any swap files, etc. you should free up enough space.  I listed many different options in my thread, as posted above.  You will need to reboot after doing those changes.
http://forums.autodesk.com/t5/Installation-Licensing/Out-of-disk-space-during-installation-to-anothe...
Good Luck!
Autodesk Forums:
Message 5 of 8
It seems that am not being clear.
I had previously optimised my C drive as I had run out of space:
1. I run CC cleaner daily
2. I run disc clean up before installing
3. I defrag on a monthly basis
4. All my temp folder are on D drive, have been for a year. I double checked.
5. Hybernation has been off for more than a year and still is.
6. All swap files are on D
7. Some of my appdata is also on D, dynamically linked
After all of this, I had 7GB free. Autodesk chooses to use more than 2GB of that to download files on C and I have no choice.
So now I am left with 5GB.
My question is NOT how to free up space. I am asking how can I get around this idiotic installation requirement?
Why do I need 15 GB on C drive to install 5GB on D drive?
Autodesk have always been somewhat careless and selfish with their installation but this is really pushing the bar high on idiocy.
Message 6 of 8
TravisNave
The only thing I can think of is that it is looking for something on C:\ as a temp space.  Is your profile temp and your Windows temp both moved to D:\ under your system environment variables?
I haven't looked that deep into the setup.ini on drive requirements, but I suspect that requirement can also be modified in that file.  Might be worth a look.
Autodesk Forums:
Message 7 of 8
maybe there is something has to be installed onto c drive. you can choose a location .if the truth is it .i suggest you to allocat some space from other drive to C drive.the is the only way.i did it by different reaon by using "partitionwizard",just few clicks.worth a try
Message 8 of 8
