Installation Error
Installation Error
Installation Error
I have tried to install AutoCAD twice now, failed both times, received error logs. I uninstalled the previously downloaded files after the first failed attempt and even set my laptop to a new restore point. I have attached the error log for anyone's use. Not sure why it's failing.
Please help.
Thanks.
Alexander.Rivilis
You can use Autodesk Virtual Agent in order to download full version and install AutoCAD.
Instruction:  Installing Autodesk products from the Virtual Agent
Hope it help you.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
TravisNave
Your materials library is failing to download.
I would recommend that you try downloading your product using the Virtual Agent by following the directions here:
https://knowledge.autodesk.com/customer-service/download-install/download/download-previous-versions...
Autodesk Forums:
