I am constantly getting a License error when trying to start Maya
I will get a licence error when starting Maya, this will continue for a few min then I will be able to start a Maya process. I have Uninstalled Maya 3 times, installed packs and updates and I am still getting this error. Has anyone gotten this and could help me with the fix:
Otto
Hello wesley.keeling
It looks like you need help uninstalling - or have issues that may be addressed by uninstalling - an Autodesk product. Community members with similar questions found the following article(s) useful: The following article(s) should help you resolve the problem:
Uninstalling a Product
Once your product is uninstalled, please try downloading your Autodesk Software using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
No Otto, that's not it. You filthy bot.
TravisNave
Hahaha Otto!
This issue has plagued Maya for years...
Here's two things you can try:
1.  Go into Windows Services and stop/start the Flexnet Service (make sure it is set for Automatic)  Then launch Maya.
2.  If that fails, go into C:\ProgramData\Flexnet and rename the adsk*.data files.  Then launch Maya.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Perfect thanks for your reply, I have set it to automatic, I'll let you know if it worked! Thanks!
