FLEXnet Licensing error:-125,147
Message 1 of 17
Hi, i just installed AutoCAD 2009 with network licensing the lmtools.exe give me this error:
his license cannot be checked out because:
A PACKAGE component must be specified.
Feature: 64300ACD_F
License path: C:\Program Files\Autodesk Network License Manager\License\ACD2009.lic;
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
"PLIST" v1.000, vendor: adskflex
License server: SERVERNAME
floating license starts: 1-jan-1990, no expiration date
is anybody ca help me ?
P.S. i had Autocad 2008 on that server and it worked
properly
Replies (16)
Message 2 of 17
This indicates that there is a problem with your license file. Try to get a
new one.
Jimmy Bergmark - Owner/Developer
JTB World - Software development and consulting
Website: http://www.jtbworld.com
Blog: http://blog.jtbworld.com
JTB FlexReport (FLEXnet / FLEXlm license report tool) -
www.jtbworld.com/jtbflexreport
AutoCAD 2009
http://www.jtbworld.com/autocad2009.htm
"ajean" wrote in message news:6017522@discussion.autodesk.com...
> give me this error:
> Feature: 64300ACD_F
> properly
> Thanks
Message 3 of 17
TravisNave
Sounds like you didn't append your 2009 license file correctly.
Autodesk Forums:
Message 4 of 17
Hi !
I tried to get a new license file twice and tried to install it on an other server . I still get the same message
client using Autocad 2008 are still able to connect to.
Any suggestions ?
Message 5 of 17
TravisNave
How are you generating your license file? And are you combining it with another license file?
Autodesk Forums:
Message 6 of 17
> other server .
Likely you're not merging those files correctly. Essentially the error
message says that there should be a line that starts with COMPONENT that is
not proper. Without telling us more specifically what you're doing it's hard
to help with.
Best regards,
Henrik Goldman
Flexlm license management to reduce your costs -
http://www.x-formation.com/license_statistics/index.html
Knowledgebase on software license management - http://kb.x-formation.com/
Protect your software with LM-X License Manager -
http://www.x-formation.com/lm-x_license_manager/index.html
Message 7 of 17
Getting the same error here, but license file was generated by Autodesk. No merging of license files were necessary.
Message 8 of 17
TravisNave
Interesting. Is there a Package increment in your license file? This is only available to customers under Subscription.
Autodesk Forums:
Message 9 of 17
Hi, i was reading this thread, i have this error, i have a .lic with 16 seats of 2009 and 15 version 2006, and i have this error, can anyone help me?
Message 10 of 17
I am having the same error. I was wondering how can you find out exactly which license is giving the error?
Ken@rlmrlm.com
Message 11 of 17
Hi Ken,
Also having the same error with Revit 2009.
Anyone have any solutions???
Nathan Witte
Design Organization
Message 12 of 17
Silvia.Menon
have a look at this doc on the Autodesk Website:
Error -125,147: This license cannot be checked out because: A PACKAGE component must be specified
http://usa.autodesk.com/getdoc/id=TS1093987
Regards
Silvia
Message 13 of 17
FWIW: This error may have to do with PACKAGE components not recognizing qualified hostnames.
I get this error when I use a hostname of the form host.domains.topdomain in my license file. When I remove it, no error.
Also, when I remove the domain information, Inventor Series 2009 will serve licenses to ACAD 2009 or ACADM 2009 as it is supposed to do. But if I have it in, it will not.
I do not have a work around for this yet, other than leaving out the domain qualifier!
I'd be interested in knowing if anyone else has further information on this issue and the -125,147 error.
Message 14 of 17
I am getting the same error with AutoCad Civil 2010 and Civil 3D 2010. Both license files were generated by Autodesk.
Additionally, when I lauch AutoCad the client tell me it cannot find a valid license and generates "Error -96.491.0"
Help Appreciated
Message 15 of 17
TravisNave
Message 16 of 17
It was the firewall on the server in my case.
Message 17 of 17
Check AutoDesk bulletin TS1093987 ...
That diagnostics feature in FlexNet did not work properly with AutoCad 2009 and obviously it does not work properly with 2010 or 2011 either because I get the same error, but the Status Inquiry indicates licenses are being check out and everything is functioning normally.  Also, I cannot find a follow-up to that bulletin which indicates that the diagnostics problem has been resolved.  I would like to see one.
