Error Code 62 on installation
ianlitterbach
ianlitterbach
Community Visitor
Community Visitor
Hi all.
I am trying to install AutoCad 25 trial version. I previously had it working but I had the trial program unistalled to enable installtion of a previous version I used to own outright. My old version can no longer be installed and autocad can't offer supprort for a product of that age. Now I have no working autocad and when I try to re-install the trail version (still has 15 days left) it fails with code 62. It takes an enormous amount of time even time I attempt to download. Any magic fixes out there? Thanks
TravisNave
You cannot reinstall a trial on that machine as it will be expired.  You will likely need to either 1.  Install the trial onto another machine, or 2. download an AutoCAD 2025 trial in a different flavor... like Mechanical.
Autodesk Forums:
Simon_Weel
Clean out all Autodesk files / folders and registry entries.
How to perform a Clean Uninstall of Autodesk products on Windows
handjonathan
Hi @ianlitterbach
Thanks a lot for posting your question to the forums!  
Can you try the following:
Reinstall the licensing service
  1. How to uninstall Autodesk Desktop Licensing Service
  2. Wait 2 to 4 minutes for the folder C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing to get empty.
  3. How to download and install Autodesk Desktop Licensing Service on Windows
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
