We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
DirectX Runtime Failed Failure is ignored, Result=1619
wordiotic
Message 1 of 10
wordiotic
Hi experts,
Need some help here. i'm trying to install autocad mechanical 2012 to my desktop (64-bit). I've read previous solved problems similar to mine. But none is exactly the same problem as mine.
I've tried looking into autodesk virtual agent, but download link for autocad mechanical 2012 is not there. the download link only available until autocad mechanical 2013.
I'd appreciate any help.
thanks in advance.
here's my log.
2016/7/18:15:38:09 NURAINH PSAGAMPC38036 PageOpen InstallCompleteDialog
2016/7/18:16:03:23 NURAINH PSAGAMPC38036 === Setup ended ===
2016/7/18:16:03:26 NURAINH PSAGAMPC38036 === Setup started on PSAGAMPC38036 by NURAINH ===
2016/7/18:16:03:26 NURAINH PSAGAMPC38036 Launch
2016/7/18:16:03:44 NURAINH PSAGAMPC38036 === Setup ended ===
2016/7/18:16:03:28 NURAINH PSAGAMPC38036 === Setup started on PSAGAMPC38036 by NURAINH ===
2016/7/18:16:03:28 NURAINH PSAGAMPC38036 Launch
2016/7/18:16:03:44 NURAINH PSAGAMPC38036 PageOpen LaunchDialog
2016/7/18:16:04:18 NURAINH PSAGAMPC38036 PageOpen LicenseDialog
2016/7/18:16:04:23 NURAINH PSAGAMPC38036 PageOpen ProductInfoDialog
2016/7/18:16:04:36 NURAINH PSAGAMPC38036 PageOpen ProductSelectionDialog2
2016/7/18:16:04:39 NURAINH PSAGAMPC38036 PageOpen FullProgressDialog
2016/7/18:16:04:39 NURAINH PSAGAMPC38036 Installing .NET Framework Runtime 4.0: H:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2016/7/18:16:04:53 NURAINH PSAGAMPC38036 Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
2016/7/18:16:04:54 NURAINH PSAGAMPC38036 PageOpen InstallCompleteDialog
2016/7/18:16:10:33 NURAINH PSAGAMPC38036 === Setup ended ===
2016/7/18:16:14:19 NURAINH PSAGAMPC38036 === Setup started on PSAGAMPC38036 by NURAINH ===
2016/7/18:16:14:19 NURAINH PSAGAMPC38036 Launch
2016/7/18:16:14:55 NURAINH PSAGAMPC38036 === Setup ended ===
2016/7/18:16:14:24 NURAINH PSAGAMPC38036 === Setup started on PSAGAMPC38036 by NURAINH ===
2016/7/18:16:14:24 NURAINH PSAGAMPC38036 Launch
2016/7/18:16:14:55 NURAINH PSAGAMPC38036 PageOpen LaunchDialog
2016/7/18:16:15:24 NURAINH PSAGAMPC38036 PageOpen BeginDeploymentDialog
2016/7/18:16:17:15 NURAINH PSAGAMPC38036 === Setup ended ===
2016/7/18:16:17:15 NURAINH PSAGAMPC38036 === Setup started on PSAGAMPC38036 by NURAINH ===
2016/7/18:16:17:15 NURAINH PSAGAMPC38036 Launch
2016/7/18:16:17:34 NURAINH PSAGAMPC38036 === Setup ended ===
2016/7/18:16:17:18 NURAINH PSAGAMPC38036 === Setup started on PSAGAMPC38036 by NURAINH ===
2016/7/18:16:17:18 NURAINH PSAGAMPC38036 Launch
2016/7/18:16:17:34 NURAINH PSAGAMPC38036 PageOpen LaunchDialog
2016/7/18:16:22:56 NURAINH PSAGAMPC38036 PageOpen LicenseDialog
2016/7/18:16:23:01 NURAINH PSAGAMPC38036 === Setup ended ===
2016/7/18:16:23:04 NURAINH PSAGAMPC38036 === Setup started on PSAGAMPC38036 by NURAINH ===
2016/7/18:16:23:04 NURAINH PSAGAMPC38036 Launch
2016/7/18:16:26:56 NURAINH PSAGAMPC38036 === Setup ended ===
2016/7/18:16:23:04 NURAINH PSAGAMPC38036 The system cannot open the device or file specified.
2016/7/18:16:26:57 NURAINH PSAGAMPC38036 === Setup ended ===
2016/7/18:17:14:36 NURAINH PSAGAMPC38036 === Setup started on PSAGAMPC38036 by NURAINH ===
2016/7/18:17:14:36 NURAINH PSAGAMPC38036 Launch
2016/7/18:17:15:03 NURAINH PSAGAMPC38036 === Setup ended ===
2016/7/18:17:15:03 NURAINH PSAGAMPC38036 PageOpen LaunchDialog
2016/7/18:17:16:08 NURAINH PSAGAMPC38036 PageOpen LicenseDialog
2016/7/18:17:16:11 NURAINH PSAGAMPC38036 PageOpen ProductInfoDialog
2016/7/18:17:16:28 NURAINH PSAGAMPC38036 PageOpen ProductSelectionDialog2
2016/7/18:17:16:30 NURAINH PSAGAMPC38036 PageOpen FullProgressDialog
2016/7/18:17:16:31 NURAINH PSAGAMPC38036 Installing DirectX Runtime: C:\Users\nurainh\Desktop\acadm2012\3rdParty\DirectX\DXSETUP.exe /silent
2016/7/18:17:17:22 NURAINH PSAGAMPC38036 Install DirectX Runtime Succeeded
2016/7/18:17:17:22 NURAINH PSAGAMPC38036 Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Users\nurainh\Desktop\acadm2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/7/18:17:17:31 NURAINH PSAGAMPC38036 Install FaroSDK Succeeded
2016/7/18:17:17:31 NURAINH PSAGAMPC38036 Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Users\nurainh\Desktop\acadm2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/7/18:17:18:14 NURAINH PSAGAMPC38036 Install Autodesk Material Library 2012 Succeeded
2016/7/18:17:18:14 NURAINH PSAGAMPC38036 Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Users\nurainh\Desktop\acadm2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/7/18:17:18:31 NURAINH PSAGAMPC38036 Install Autodesk Material Library 2012 - Low Resolution Succeeded
2016/7/18:17:18:31 NURAINH PSAGAMPC38036 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Users\nurainh\Desktop\acadm2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/7/18:17:23:35 NURAINH PSAGAMPC38036 Install Autodesk Content Service Failed Failure is ignored, Result=1603
2016/7/18:17:23:38 NURAINH PSAGAMPC38036 Installing AutoCAD® Mechanical 2012: TRANSFORMS="C:\Users\nurainh\Desktop\acadm2012\x64\en-us\acadm\acad.mst;C:\Users\nurainh\AppData\Local\Temp\_AID942.tmp\x64\acadm\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Users\nurainh\Desktop\acadm2012\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Mechanical 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/7/18:17:27:59 NURAINH PSAGAMPC38036 Install AutoCAD® Mechanical 2012 Succeeded
2016/7/18:17:28:02 NURAINH PSAGAMPC38036 Installing AutoCAD® Mechanical 2012 Language Pack: TRANSFORMS="C:\Users\nurainh\AppData\Local\Temp\_AID942.tmp\_la1BD6.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Users\nurainh\Desktop\acadm2012\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Mechanical 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/7/18:17:30:41 NURAINH PSAGAMPC38036 Install AutoCAD® Mechanical 2012 Language Pack Succeeded
2016/7/18:17:30:41 NURAINH PSAGAMPC38036 Installing .NET Framework Runtime 4.0: C:\Users\nurainh\Desktop\acadm2012\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2016/7/18:17:31:20 NURAINH PSAGAMPC38036 Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
2016/7/18:17:31:53 NURAINH PSAGAMPC38036 Rollback AutoCAD® Mechanical 2012 Language Pack Succeeded
2016/7/18:17:33:49 NURAINH PSAGAMPC38036 Rollback AutoCAD® Mechanical 2012 Succeeded
2016/7/18:17:34:05 NURAINH PSAGAMPC38036 Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2016/7/18:17:34:27 NURAINH PSAGAMPC38036 Rollback Autodesk Material Library 2012 Succeeded
2016/7/18:17:34:31 NURAINH PSAGAMPC38036 Rollback FaroSDK Succeeded
2016/7/18:17:34:31 NURAINH PSAGAMPC38036 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Replies (9)
Message 2 of 10
Otto
Hello wordiotic
It looks like you are seeing Error 1619 while trying to install a program. The following article(s) should help you resolve the problem:
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Autodesk program installation fails
BIM 360 Add-in install error: "A newer version of this software is already installed"
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 10
Mark.Lancaster
@wordiotic
The 2012 version is retired/unsupported anymore so you will not find any "live" download links.
Your installation is failing on netframe 4.0 and the Autodesk content services.
Is this a new machine?  What is the operating system?   Hopefully its not Windows 10, because its not supported.
Most likely you have a newer version of netframe on this pc.  I would start there...
Mark Lancaster
Message 4 of 10
wordiotic
@Mark.Lancaster
My current computer already installed with netframe 4.5. For Autocad Mechanical 2012, it required the netframe to be 4.0.
So, I made some changes to the setup.imi file based on solved problem from this forum. And the installation worked quite well up to 85%, then this error popped up.
I'm using windows 7,btw.
Message 5 of 10
Darin.Green
You need to uninstall .net frameworks from your machine and let the Autodesk software install it.
If this information was helpful, please consider using the Accept Solution
Message 6 of 10
TravisNave
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
If the prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Autodesk Forums:
Message 7 of 10
wordiotic
@Darin.Green@TravisNave
I've uninstalled my net framework 4.5. And i start over the Autocad installation process, then this error popped up at progress of 6 of 12.
I clicked "OK" and the installation resumes. Does this error affect anything?
But, the good news is... the installation is finally completed.
Kudos to all that helped.
Message 8 of 10
TravisNave
I wouldn't sweat it. You should be good to go!
Autodesk Forums:
Message 9 of 10
Darin.Green
The main issue was related to .net framework which is why I asked you to uninstall and let the software install it which seemed to work. In regards to the error message you just received, its nothing you have to worry about as @TravisNave pointed out. The service that failed is used for scanning your pc or network share to index blocks and other content for importing into your model. <-- Most people don't use it or even know what it does.
Message 10 of 10
Apenas desativei o antivirus e o Firewall e deu tudo certo.
