- Mute
- Permalink
- Report
I have read many of the documents in the knowledge base, watched some youtube videos and they all state to use a UNC for the administrative image path location > yet when I put a UNC in the path as part of a deployment creation I get an error that \ is a character I can't use.. So I create the deployment to a local folder on the workstation I am creating the deployment from > then afterwards copy the deployment to my share > then modify the setup shortcut to use a UNC as well both ini files in the Img folder (section was global msi properties - I changed from a local folder to the UNC path to the deployment folder on the server.
I can right click on the setup link from a workstation and run as administrator and the install kicks off but the installation is stuck on 'Initializing' - did I create the deployment correctly? Did I break the deployment by changing the ini settings? I have spent a good 3 days on this and am at a loss, waiting for the support chat agent to pick up and thought I would throw this out to the forum to see if anyone can provide direction.
Autodesk revit 2016
I configure a network deployment with distributed license servers
workstation installing on is windows 10 all updated
I have no antivirus running on this test station - we use CylancePROTECT in house so will have to deal with that one after I get a base install working
I want to move this to SCCM to get benefits of wider distribution etc..
Thanks for any assistance!!
