Computer Cloning
Computer Cloning
Computer Cloning
I have made a clone of a computer with AutoDesk 2016. I would like to know how to strip out the software serial number, so that I can make another clone with no license information. That way when we get a new user, I just fire up that clone and add a new AutoDesk license and they are ready to go, quickly.
If someone could please tell me how to cut a serial number out of the software, that would be very helpful.
Otto
Hello robertWEG86 and welcome to the Autodesk community!
It looks like you want information on managing your Autodesk licenses. Community members with similar questions found the following article(s) useful:
How to understand and manage your Autodesk licenses (video)
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
This is not helpful, as that question I'm asking is not a common question that a standard video can answer. Again, I want to know how to remove a serial number from AutoDesk 2016. Keep in mind the License Transfer Utiilty does not work in this scenario, because, since the software was registered form another physical machine, it sees this machine as a fraud. My goal here is to increase effeciency, by having an unlicensed image of a computer with AutoDesk 2016, ready and waiting, everytime we add a new PC to our environment. That way I can set up users quickly.
TravisNave
Generally cloning doesn't work well on stand-alone versions like it does on
network ones. Your best bet is to install as trial before cloning.
Otherwise maybe delete the license files under
C:\ProgramData\Flexnet\adsk*.data then activate.
Good Luck!
Autodesk Forums:
This worked perfectly, for what I'm trying to do! Thank you so much for the information.
TravisNave
Awesome!  Glad you got it working!
Autodesk Forums:
dgorsman
If you have any more than a handful of licenses, start working towards network licensing.  Much, much better solution!
