Cannot reinstall Inventor 2023 even after clean uninstall and MSfixitTool
fuzzyman_verity
Observer Observer
fuzzyman_verity
Observer
Observer
I was having issues with with my license activation so I decided to reinstall Inventor 2023, and after uninstalling it I was not able to reinstall due to the last install not being completely removed. I tried to use the MSfixitTool to remove what was left of Inventor with it failing to do so. I then followed the Clean Uninstall guide to no avail. MSfixitTool is still showing that Inventor is still there but it fails to remove it. What can I do now other than reinstall windows?
TravisNave
Make sure that there are no instances of the files in Program Files, ProgramData, Common Files, or the Windows registry.  Clearly it is finding some remnants that is causing an issue.  I assume it is no longer listed in Control Panel? If you still have issues, post your installation log file here.
Autodesk Forums:
andr3sant0s
Hi @fuzzyman_verity
In this kind of situation I usually use this troubleshooter.
https://support.microsoft.com/en-us/topic/fix-problems-that-block-programs-from-being-installed-or-r...
Please use Accept as Solution and like/Give Kudos as appropriate to further enhance these forums.
handjonathan
Hi @fuzzyman.verity
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @TravisNave @andr3sant0s  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
