Can I copy an install image to another server?
JamesMaeding
Advisor Advisor
JamesMaeding
I made our install images on one server, and want to copy them to another office's.
I read the articles on this and they talk about a \tools\deployment\ folder and I don't have that.
I think that is when you want the install to run from the web.
My install image has a batch file in the root, then an image folder.
Then a bunch of products under, like this:
Its an AEC Collection image, so several products.
My question is can I copy this image to another server and edit the xml files to point to it, to make it work?
Or is it intended that each image is keyed to a server and we are to remake them.
Its a ton of files and takes a while to make the images so a remake would be undesirable.
However, maybe its not such a bad idea if the media gets downloaded compressed.
Curious what others do for multiple offices.
thanks,
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
rushabhthakkar_910
@JamesMaeding, Have a look at this..!!
(https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-m...)
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
JamesMaeding
@rushabhthakkar_910
I read that before, and specifically mentioned my install image seems different.
Please re-read my post.
thx
TravisNave
Yes.  You can do this.
Autodesk Forums:
JamesMaeding
Cool, just looking for red flags and you would know. thx
