Anyone else run into the problem where it hangs at the Hub is being configured intro screen? This is happening on a pcs that previously had the beta on it as well as one that never did. Also after removing all the folders mentioned in the cleanup portion of the faq the only thing that changes is it asks me to log in prior to hanging at this point. Thanks in advance!
p-
Solved by brianrepp. Go to Solution.
Same here, created an account yesterday for the personal edition, installed and started the app, was asked for a name for the hub. Then it just stalls in a login loop with the website. When trying to access the hub using the browser, it gets stuck in a loop saying "hub is being configured" - have not been able to use the product at all so far.
Tried it completely fresh today with a new emal address and acount, still not luck.
@az476 Thanks for the email. Working with my engineering team on this.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
I’m having the same issue, after creating an account and downloading Fusion 360 from the UK site. I followed the setup inside the app, after it had installed.
To @RajkumarIlanchelian Hi, i also seem to be experiencing the same problem after following the install through the windows app, stuck in a loop at the 'hub is being configured' page, any help will be greatly appreciated
Many thanks
There was an ongoing service incident that mentioned issues with new accounts (https://health.autodesk.com/incidents/64y0f3dvlc48). This has been resolved now.
However, I am still not able to sign in and keep getting stuck in a sign-in-loop in the Fusion desktop application, and also on the Fusion Team Onboarding site (“Hub is being configured”).
@patrickUPP25 Yes, the incident it self is resolved to the point that new issues will not happen. We are still working to correct all the impacted accounts.
Autodesk Fusion
Join Fusion Insider
Hello, I am also wondering when the impacted accounts may be fixed.
I used mohawk876@hotmail.com to register, and the verification failed. The website said the link expired. This happened immediately after I received the email.
Hello I have created a new fusion account, and created a hub, I cannot sign in, (Stuck in a infinite loop), and my hub will not configure, will this resolve itself with time?
Yesterday I've created my student account and I have the same issue how can i fix this issue.
I had the same experience. I can now access Fusion.
Thank you for your help all who contributed!
Update on sign-in loop or hub is being configured.
We have now fixed all the accounts that were impacted due to this problem. You should be able to login to Fusion or Fusion team (https://login.autodesk360.com/login) and have access to Fusion.
We sincerely apologies for the inconvenience caused here.
IF any accounts are still facing this issue, please reach out!
Autodesk Fusion
Join Fusion Insider
Hello @RajkumarIlanchelian,
I am having the same issue as @ldent59TVB. I reached out to customer support the other day, but they couldn't help. If you can help me, I will directly message you my email.
Thank you
@michaeldunnD Your account should be fixed now. Please let us know.
Autodesk Fusion
Join Fusion Insider
