Anyone else run into the problem where it hangs at the Hub is being configured intro screen? This is happening on a pcs that previously had the beta on it as well as one that never did. Also after removing all the folders mentioned in the cleanup portion of the faq the only thing that changes is it asks me to log in prior to hanging at this point. Thanks in advance!
p-
Solved by brianrepp. Go to Solution.
@n_whipple Can you please direct message me your email used to register Fusion?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
@n_whipple You should be all good now. Please login again.
Autodesk Fusion
Join Fusion Insider
I was able to login the other day and haven't used it since. I tried again today, and when I try to log in via web this happens again (the "Your account is being configured") loop.
Edit: I believe the issue is that I've joined a hub that has a domain and that's causing issues. Just recreated an account with my email account for that domain and it's fixed.
Best,
Anton (email antonwpb@gmail.com)
@antonwpb Glad it is fixed. Let us know if you have any other issues.
Autodesk Fusion
Join Fusion Insider
Hi! I'm having the same issue as ldent59TVB and n_whipple, also in the same class. Could I please get some help with this?
TY!
@kjc236 Looks like what is happening here is that I assume your teacher sent you an invite and once you accepted the invite there should be another email that contains a link that you need to click to "complete" the Fusion enrollment.
I can help you now but will need your email ID that you used to register. Please send it to me via a DM.
Autodesk Fusion
Join Fusion Insider
Hi! I have also been having similar issues as Ident59TVB and wondering if I could receive some help with this problem.
My Email is joana@ucsb.edu
Hi! I am also having the same issue as ldent59TVB. and the other people in this thread, could I have some assistance with this issue?
My email is joana@ucsb.edu
@joana9DSBZ Your account shows that this was actived as a "closed" account. Can you login to https://login.autodesk360.com/login and see if you are able to login?
Autodesk Fusion
Join Fusion Insider
Hi! I am also stuck in the hub configuration, could I get some help with this issue?
@joana9DSBZ Looks like your situation is different. Did you get a chance to look at my above post to you?
Autodesk Fusion
Join Fusion Insider
Hi, yes I deleted fusion from my computer to reinstall it and hopefully fix the issue but I am still having the same issue. When trying to join the hub for my course it says in the account configuration.
Hello I'm also stuck on the "Hub is being configured" page, would appreciate some help. I'm additionally stuck on the sign in loop so I'm not able to log into Fusion360 in the first place. To solve this issue, I need to first log into the hub but I'm stuck on "Hub is being configured" so I can't do anything. My email is az476@cornell.edu
I am the admin for my team but I created the team during registration, and am not able to access this site because of the infinite "Hub is being configured" loop: https://login.autodesk360.com/login
Like other people in this thread I'm locked at the page "Hub is being configured" that keeps looping and looping again on my browser.
Thanks in advance for your help!
@turha @istosic10921rn @vkalashnikava @yann_giraudet Can you all send me direct message of your email ID used to register for Fusion?
Also, can you all tell me how you were invited to Fusion and what process you followed?
Autodesk Fusion
Join Fusion Insider
