Stalling at "Hub is being Configured"
119 REPLIES 119
Message 1 of 120
pmarchese
6929 Views, 119 Replies
Anyone else run into the problem where it hangs at the Hub is being configured intro screen? This is happening on a pcs that previously had the beta on it as well as one that never did. Also after removing all the folders mentioned in the cleanup portion of the faq the only thing that changes is it asks me to log in prior to hanging at this point. Thanks in advance!
p-
119 REPLIES 119
Message 64 of 120
georgeyfa
in reply to: pmarchese
exact same thing here as well !!!
Message 65 of 120
@georgeyfa @maxWU5JZ We are actively looking into this. WE believed this should have been addressed but there seems to be a small group that this is not yet addressed and we are looking into why.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 66 of 120
@georgeyfa @maxWU5JZ Can you please close Fusion 360 and launch/login again? We believe we have addressed this issue now.
Autodesk Fusion
Join Fusion Insider
Message 67 of 120
georgeyfa
it's solved
Message 68 of 120
ldent59TVB
It seems I'm having the same problem as others in this thread. I'm trying to activate my Fusion 360 account and join a group and it keeps stalling at "Your account is being configured". Any way to fix this?
Message 69 of 120
@ldent59TVB Can you please try to login to https://login.autodesk360.com/login and see if that completed the hub creation?
Autodesk Fusion
Join Fusion Insider
Message 70 of 120
That brought me to a page that sent me an email invitation, the same one I have been trying to use to activate my account that leads me to the page that stalls.
Message 71 of 120
ldent59TVB
in reply to: ldent59TVB
Following up - I would love if this could get resolved as soon as possible, as I have a class I need this program for. I am pretty certain this is a problem on Fusion's end as I have tried every way to fix it.
Message 72 of 120
@ldent59TVB Can you please direct message me your email that was used to register Fusion?
Autodesk Fusion
Join Fusion Insider
Message 73 of 120
Yes, my email is @ldent@ucsb.edu. Thank you.
Message 74 of 120
@ldent59TVB you should be all good to login now.
Autodesk Fusion
Join Fusion Insider
Message 75 of 120
I read through this forum and I'm having a similar issue to ldent59TVB. I cannot login online.
My email is antonwpb@gmail.com
Message 76 of 120
@antonwpb You should be all good now.
Autodesk Fusion
Join Fusion Insider
Message 77 of 120
Thank you! I can now use the software but I still can't join my class's group (MAD 111PF) from the invite I received. The same page keeps stalling, not sure why.
Message 78 of 120
@ldent59TVB When you log into Fusion and use the dropdown as shown in the image do you see your class hub in there?
Autodesk Fusion
Join Fusion Insider
Message 79 of 120
I just checked in Fusion and it looks like I am in the group now. Thank you so much!
Message 80 of 120
Hi! I have also been having similar issues as Ident59TVB and wondering if I could receive some help with this problem.
My Email is joana@ucsb.edu
Message 81 of 120
n_whipple
Hi! I am also having the same issue as ldent59TVB, and I am in the same class as well. Any chance I could get some help with this?
Thanks 🙂
Message 82 of 120
@n_whipple Can you please direct message me your email used to register Fusion?
Autodesk Fusion
Join Fusion Insider
Message 83 of 120
@n_whipple You should be all good now. Please login again.
Autodesk Fusion
Join Fusion Insider
Message 84 of 120
It works. Thank you for your help! 🙂
