Stalling at "Hub is being Configured"
pmarchese
pmarchese
Anyone else run into the problem where it hangs at the Hub is being configured intro screen? This is happening on a pcs that previously had the beta on it as well as one that never did. Also after removing all the folders mentioned in the cleanup portion of the faq the only thing that changes is it asks me to log in prior to hanging at this point. Thanks in advance!
p-
Replies (119)
RajkumarIlanchelian
@patrickUPP25 Yes, the incident it self is resolved to the point that new issues will not happen. We are still working to correct all the impacted accounts.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
patrickUPP25
Do you happen to have any ETA when impacted accounts should be fixed?
I would like to plan a bit ahead whether I can expect to be able to try out Fusion any time soon.
patrickUPP25
I just retried accessing Fusion and it prompted me to create a new Team Hub, with the previous one apparently being removed. After creating the new Team, Fusion is now working.
mohawk
Observer
Observer
I had the same experience. I can now access Fusion.
Thank you for your help all who contributed!
az476
I am also wondering when impacted accounts may be fixed. Thank you for your efforts, greatly appreciated.
wondershaker42
Community Visitor
Community Visitor
Hello !
I have the same sign in problem !
mohawk
Observer
Observer
Hello, I am also wondering when the impacted accounts may be fixed.
I used mohawk876@hotmail.com to register, and the verification failed. The website said the link expired. This happened immediately after I received the email.
Community Visitor
Community Visitor
Hello I have created a new fusion account, and created a hub, I cannot sign in, (Stuck in a infinite loop), and my hub will not configure, will this resolve itself with time?
dr4k3y
Community Visitor
Community Visitor
I seem to be having the same issues, any ideas how to get past it?
an_lukas_maier
Community Visitor
Community Visitor
Yesterday I've created my student account and I have the same issue how can i fix this issue.
RajkumarIlanchelian
Update on sign-in loop or hub is being configured.
We have now fixed all the accounts that were impacted due to this problem. You should be able to login to Fusion or Fusion team (https://login.autodesk360.com/login) and have access to Fusion.
We sincerely apologies for the inconvenience caused here.
IF any accounts are still facing this issue, please reach out!
Autodesk Fusion
Join Fusion Insider
az476
Issue resolved, thank you so much!
michaeldunnD
Community Visitor
Community Visitor
Hello @RajkumarIlanchelian
I am having the same issue as @ldent59TVB. I reached out to customer support the other day, but they couldn't help. If you can help me, I will directly message you my email.
Thank you
RajkumarIlanchelian
@michaeldunnD Your account should be fixed now. Please let us know.
Autodesk Fusion
Join Fusion Insider
dr4k3y
Community Visitor
Community Visitor
I don't seem to have the issue anymore, thank you for sorting this out for me
