Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Stalling at "Hub is being Configured"
119 REPLIES 119
Message 1 of 120
pmarchese
6927 Views, 119 Replies
Anyone else run into the problem where it hangs at the Hub is being configured intro screen? This is happening on a pcs that previously had the beta on it as well as one that never did. Also after removing all the folders mentioned in the cleanup portion of the faq the only thing that changes is it asks me to log in prior to hanging at this point. Thanks in advance!
p-
119 REPLIES 119
Message 85 of 120
antonwpb
in reply to: pmarchese
I was able to login the other day and haven't used it since. I tried again today, and when I try to log in via web this happens again (the "Your account is being configured") loop.
Edit: I believe the issue is that I've joined a hub that has a domain and that's causing issues. Just recreated an account with my email account for that domain and it's fixed.
Best,
Anton (email antonwpb@gmail.com)
Message 86 of 120
@antonwpb Glad it is fixed. Let us know if you have any other issues.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 87 of 120
kjc236
Hi! I'm having the same issue as ldent59TVB and n_whipple, also in the same class. Could I please get some help with this?
TY!
Message 88 of 120
@kjc236 Looks like what is happening here is that I assume your teacher sent you an invite and once you accepted the invite there should be another email that contains a link that you need to click to "complete" the Fusion enrollment.
I can help you now but will need your email ID that you used to register. Please send it to me via a DM.
Autodesk Fusion
Join Fusion Insider
Message 89 of 120
@kjc236 You should be good to go now.
Autodesk Fusion
Join Fusion Insider
Message 90 of 120
joana9DSBZ
Hi! I am also having the same issue as ldent59TVB.  and the other people in this thread, could I have some assistance with this issue?
My email is joana@ucsb.edu
Message 91 of 120
@joana9DSBZ Your account shows that this was actived as a "closed" account. Can you login to https://login.autodesk360.com/login and see if you are able to login?
Autodesk Fusion
Join Fusion Insider
Message 92 of 120
joana9DSBZ
Hi! I am also stuck in the hub configuration, could I get some help with this issue?
Message 93 of 120
@joana9DSBZ Looks like your situation is different. Did you get a chance to look at my above post to you?
Autodesk Fusion
Join Fusion Insider
Message 94 of 120
Hi, yes I deleted fusion from my computer to reinstall it and hopefully fix the issue but I am still having the same issue. When trying to join the hub for my course it says in the account configuration. Screenshot 2024-07-03 at 3.46.09 PM.png
Message 95 of 120
az476
Hello I'm also stuck on the "Hub is being configured" page, would appreciate some help. I'm additionally stuck on the sign in loop so I'm not able to log into Fusion360 in the first place. To solve this issue, I need to first log into the hub but I'm stuck on "Hub is being configured" so I can't do anything. My email is az476@cornell.edu
I am the admin for my team but I created the team during registration, and am not able to access this site because of the infinite "Hub is being configured" loop: https://login.autodesk360.com/login
Message 96 of 120
RajkumarIlanchelian
in reply to: az476
@az476 Thanks for the email. Working with my engineering team on this.
Autodesk Fusion
Join Fusion Insider
Message 97 of 120
To @RajkumarIlanchelian
I’m having the same issue, after creating an account and downloading Fusion 360 from the UK site. I followed the setup inside the app, after it had installed.
Message 98 of 120
yann_giraudet
Like other people in this thread I'm locked at the page "Hub is being configured" that keeps looping and looping again on my browser.
Thanks in advance for your help!
Message 99 of 120
turha
Also stuck with "Hub is being configured".
Message 100 of 120
istosic10921rn
I'm also stuck with "Hub is being configured"
Message 101 of 120
vkalashnikava
I'm also stuck with "Hub is being configured" and log in issue (first time log in).
Message 102 of 120
@turha @istosic10921rn @vkalashnikava @yann_giraudet Can you all send me direct message of your email ID used to register for Fusion?
Also, can you all tell me how you were invited to Fusion and what process you followed?
Autodesk Fusion
Join Fusion Insider
Message 103 of 120
domFCRWZ
Same here, created an account yesterday for the personal edition, installed and started the app, was asked for a name for the hub. Then it just stalls in a login loop with the website. When trying to access the hub using the browser, it gets stuck in a loop saying "hub is being configured" - have not been able to use the product at all so far.
Tried it completely fresh today with a new emal address and acount, still not luck.
Message 104 of 120
1994_ryan_j
To @RajkumarIlanchelian Hi, i also seem to be experiencing the same problem after following the install through the windows app, stuck in a loop at the 'hub is being configured' page, any help will be greatly appreciated
Many thanks
Message 105 of 120
patrickUPP25
There was an ongoing service incident that mentioned issues with new accounts (https://health.autodesk.com/incidents/64y0f3dvlc48). This has been resolved now.
However, I am still not able to sign in and keep getting stuck in a sign-in-loop in the Fusion desktop application, and also on the Fusion Team Onboarding site (“Hub is being configured”).
