Anyone else run into the problem where it hangs at the Hub is being configured intro screen? This is happening on a pcs that previously had the beta on it as well as one that never did. Also after removing all the folders mentioned in the cleanup portion of the faq the only thing that changes is it asks me to log in prior to hanging at this point. Thanks in advance!
p-
Link copied
