Modify Drawer STL
Modify Drawer STL
3D_Ken
Message 1 of 66
Modify Drawer STL
3D_Ken
I have an STL file of a drawer that I need to modify to make the drawer deeper while keeping the top part unchanged.  It is my understanding that the first step is to import the STL as a mesh.  I have done this, but I don't know what the next step is.  My only thought is converting the mesh into a body, slicing the body in two, separating the two sections and finding a way to fill in the space.  Is this what I should do, or is there a better way?
STL and F3D attached.
Replies (65)
Message 41 of 66
TheCADWhisperer
@3D_Ken
The most powerful tip in all of Fusion.
Click, drag, observe behavior.
Edit: Removed corrupted video.
Message 42 of 66
3D_Ken
I'm really sorry for being so dense, but I can not tell which two points/lines you are making coincident.
Nothing works for me.
Message 43 of 66
TheCADWhisperer
@3D_Ken
Oops, I didn't watch the video.
My screen recording software did not pick up my actions.
I record it again and check it this time before I post.
Check back in a minute.
Message 44 of 66
TheCADWhisperer
@3D_Ken
Try this one...
Message 45 of 66
3D_Ken
The lines don't turn black in your video.
Message 46 of 66
TheCADWhisperer
@3D_Ken
I accidentally embedded the same video.
Just now replaced with correct video (I hope).
Message 47 of 66
3D_Ken
Got it!
File attached.
Message 48 of 66
TheCADWhisperer
@3D_Ken
I don't like to jump ahead as I found another error and jumping ahead just leads to more errors, but -
attached is sort of where we are going with this (need to add Fillets before Shell).
I am going to be traveling on the road most of today and not sure how much help I will be able to give.
Message 49 of 66
3D_Ken
I added Fillets and then worked on the shell.  I could not figure out what to select to get the shell right, but I just kept trying until I was able to duplicate your example.  I still don't know what the rules are for setting up the shell, but I think I stumbled across the correct solution.  If you could explain the Shell faces selection, it would be helpful.
I have attached my latest version.
The only complex thing left seems to be the bottom half of the handle.
Message 50 of 66
TheCADWhisperer
@3D_Ken
What is the source of the original model?
Based on my experience I would expect to see indentation on the bottom for these ribs with uniform thickness...
Message 51 of 66
3D_Ken
It came from Printables.com.  There were several different options, some with ribs and some without.  I'm really not that concerned with the ribs, I can tinker with them later.  What I really want to complete is the lower part of the handle.
Message 52 of 66
3D_Ken
Message 53 of 66
TheCADWhisperer
@3D_Ken
I'll be back in a bit with an update.
Message 54 of 66
TheCADWhisperer
@3D_Ken
I cleaned up the sketches a bit based on what was learned from the earlier attempts.
See the Attached file...
In your original problem description, you mentioned that your Design Intent was to change some dimensions.
In the Attached file Edit the Named Parameters Width, Depth and Height as needed to match your true Design Intent.
Message 55 of 66
3D_Ken
I almost always put in parameters for anything that might change.  You can see this in the prior versions that I have posted.
I also have gone back and put in big changes to see if I could break anything, and everything worked as I hoped it would.
Where do we go from here?
Message 56 of 66
3D_Ken
Shouldn't the lower handle indentation be on one of the existing sketches, or is there yet another sketch to be added?
Message 57 of 66
TheCADWhisperer
@3D_Ken
The lower handle will be a rotation copy (Circular Pattern) of the upper handle, so no sketch needed for that feature.
Message 58 of 66
3D_Ken
Do I rotate faces on the sketch, or the body of the handle?
I tried both and could not make either of them produce the desired results.
Message 59 of 66
TheCADWhisperer
@3D_Ken
There is a trick needed first.
Split the Handle Body from the Drawer.
Circular Pattern Body.
Combine-Join.
Attach your file here.
Message 60 of 66
3D_Ken
I tried to follow your instructions, but it didn't come out quite right.
See attached.
