Modify Drawer STL
Modify Drawer STL
3D_Ken
Message 1 of 66
Modify Drawer STL
3D_Ken
I have an STL file of a drawer that I need to modify to make the drawer deeper while keeping the top part unchanged.  It is my understanding that the first step is to import the STL as a mesh.  I have done this, but I don't know what the next step is.  My only thought is converting the mesh into a body, slicing the body in two, separating the two sections and finding a way to fill in the space.  Is this what I should do, or is there a better way?
STL and F3D attached.
Replies (65)
Message 21 of 66
TheCADWhisperer
@3D_Ken
I see blue lines and a white dot - these should keep you awake at night.
Click and drag the indicated points.
What do you observe?
OK, I see you have posted an updated file.
I will work on the next set of steps...
For the angles I simply sketched them relative to the imported geometry visually and then added logical dimensions.
Message 22 of 66
3D_Ken
Already fixed in V5 an hour ago.
Message 23 of 66
3D_Ken
"I will work on the next set of steps..."
I think there is a bunch of stuff (not all) that I can do on my own.  The only thing I'm not sure of is the handle.
Should I give it a try?
Message 24 of 66
TheCADWhisperer
@3D_Ken
I am going to be tied up for a bit.  Give it a try on your own.
JD
Message 25 of 66
TheCADWhisperer
@3D_Ken
Hints:
Sketch top view.
Extrude
Extrude Intersect
Extrude Intersect
Shell
Message 26 of 66
3D_Ken
I'm afraid that I've gone as far as I can, and I'm in over my head.  Attached is my latest file.  It has everything but the handle parts.
I've sketched the top view, but don't know where to go from here.
Message 27 of 66
TheCADWhisperer
@3D_Ken
You are doing wayyy too much work.
Sketch2 should look like this and nothing more...
Message 28 of 66
3D_Ken
I got things back the way they were (matching your diagram).  However, I don't understand what is wrong with my Sketch-4, or how to make it right.  Fusion keeps telling me to "re-select reference geometry", but "redefine sketch plane" doesn't fix it.
Current design attached.
Message 29 of 66
TheCADWhisperer
@3D_Ken
Your Sketch4 was created on existing Extrusion that you deleted.  We (almost) never ever create a sketch on anything except the Origin Planes (at least as a beginner).
Delete Sketch4 anyhow - it is not what we want.
Message 30 of 66
TheCADWhisperer
@3D_Ken
Your 3rd sketch should be on the XY Plane and look something like this...
Keep your sketches simple.
Edit: Oh wait a minute, I see a huge number of Symmetry Constraints in your Sketch2.  I never instructed that?  Did you use Mirror?
OK, I went back through my instructions.  I don't see where I said use Mirror or Symmetry?  I do see where I said use Equal (=) Constraint.
Message 31 of 66
3D_Ken
"I don't see where I said use Mirror or Symmetry? "
I did use mirror, it seemed easier.  Should I go back and change it?
Message 32 of 66
3D_Ken
Here is my progress file.  I can remove the mirror if you want me to.
Message 33 of 66
TheCADWhisperer
Mirror is computationally expensive (read slow), on this simple geometry it might not matter but best to get out of this habit now.
We will use only the most robust modeling techniques.
Remove the Mirror and use Equal instead.
Message 34 of 66
TheCADWhisperer
@3D_Ken
You have unnecessary dimensions (I might let the function dimensions slide, but) use Project points from the earlier sketches and Coincident Constraints rather than duplicating dimensions.
You will like the next couple of steps once we get these three simple sketches defined.
Message 35 of 66
3D_Ken
I put the dimensions in to get the lines to turn black.  If I take them out, they turn blue again.
File attached.
Message 36 of 66
TheCADWhisperer
@3D_Ken
The pro technique is to use Project (geometry) and Coincident constraints instead of repeating dimensions.
Message 37 of 66
3D_Ken
I projected the rectangle dimensions, but I can't figure out how to get rid of the 22.57 mm and the 35.3 degree dimensions without creating blue lines.
Message 38 of 66
3D_Ken
I projected the rectangle so I was able to get rid of those dimensions, but I can't figure out how to get rid of the 22.57 mm and 35.3 degree dimensions without creating blue lines.
Message 39 of 66
TheCADWhisperer
@3D_Ken
For the angled lines delete the dimension and make them Equal (=).
For the distance Project this point down from Sketch1 and then set a Coincident Constraint between the projected point and the line.
Of course, delete that 22.57 dimension before attempting to add the Coincident.
Message 40 of 66
3D_Ken
I tried doing what you said, and just can't get rid of the blue lines.  File attached.
