Cannot Edit Sketch
Cannot Edit Sketch
joeMVETK
Cannot Edit Sketch
joeMVETK
I added a 2.5mm hole to a component in an assembly, but I need to change its location. When I "edit in place" that component then right-click the sketch then select "Edit Sketch" I cannot select any part of the sketch including the hole dimeter or distance constraint to change it.
What am I doing wrong here???
TheCADWhisperer
@joeMVETK
Do you have Capture Design History enabled?
Is the sketch in the Component?
