July 2025 Update and Community Bug Fixes (Design)
seth.madore
Community Manager Community Manager
Message 1 of 1
seth.madore
Hello to the Fusion Design Community!
As always, we greatly appreciate you taking time out of your busy schedule to notify us of the issues that you find in Fusion, and we would like to show that appreciation!
As part of our ongoing effort to increase both transparency and communication with you, we're continuing with our initiative of calling out all the Forum Reported bug fixes that are included in the upcoming update. The list below comprises all the issues that have been raised specifically by our very-engaged community. So, without further ado, here is what we're going to see in the July 2025 update (creator of forum thread and the thread itself, in no particular order):
Design
For Sheet metal Flat Patterns, you will want to use Configurations to drive the appropriate numbering. THIS thread and THIS thread
@gvisca44
@carl_j_barker
@AlessandroZap
Exporting a DXF will retain Custom Units setting, provided they are compatible with export type (not...
@jlalevee
API: Decal positions should no longer be rotated around the Z when created via API
@hajime2MRG3
You should no longer be dealing with the visual oddity when toggling Display Modes
@TheCADWhisperer
Offset curves should no longer be the recipient of normal dimensions, only reference.
@HughesTooling
Tangent Dimensions should now be placed closer to where the target was selected
@kb9ydn
API: Textbox value should be getting flushed by slider movement
@Shubham_shinde54DT9
We should properly be clearing lost projection warnings when all related data are deleted
HERE and HERE
@kristianY3VSG
@evilc
Just as in prior updates, this isn’t to suggest that these are the only fixes that we've included in the update. The list above are the issues specific to what’s been reported by the Design/Support community; within this update our team has additionally found and fixed well over 100 different bugs and issues.
Still haven’t seen your issue on the list and wondering if/when it's going to get fixed? Don't hesitate to "bump" the original thread that you created, and I'll be happy to chase down the status of your issue!
Thanks again for contributing to what makes the software truly great!
Click here to see release notes from prior updates:
May 2025 – Design patch Notes
March 2025 – Design Patch Notes
January 2025 – Design Patch Notes
November 2024 – Design Patch Notes
September 2024 – Design Patch Notes
July 2024 – Design Patch Notes
May 2024 – Design Patch Notes
March 2024 – Design Patch Notes
Seth Madore
Replies (0)
