May 2025 Update and Community Bug Fixes (Design)
seth.madore
Community Manager Community Manager
seth.madore
Hello to the Fusion Design Community!
As always, we greatly appreciate you taking time out of your busy schedule to notify us of the issues that you find in Fusion, and we would like to show that appreciation!
As part of our ongoing effort to increase both transparency and communication with you, we're continuing with our initiative of calling out all the Forum Reported bug fixes that are included in the upcoming update. The list below comprises all the issues that have been raised specifically by our very-engaged community. So, without further ado, here is what we're going to see in the May 2025 update (creator of forum thread and the thread itself, in no particular order):
Design
Legacy files should retain their P/N’s for flat patterns when opening in current Fusion
Same issue with this thread
@AlessandroZap
@gvisca44
Render “Depth of Field” should now be working correctly
@SMottaghi
Mac OS; the “Workplace Switcher” should now be placed to align with PC behavior
@FrodoLoggins
Mac OS: Panning with trackpad should have better performance
@brandon_mullin
API: The Decal position should finally be in the correct position
@hajime2MRG3
API: Script and Add-In UI now persists visibility and sorting settings
@dames123
API: Creating fillets should be more successful if you can create it manually
@muhaiR2SPM
Joints and Configurations should cooperate with each other in a better fashion now
@AncientCowboy
“Extrude” should be a bit more robust when selecting multiple profiles
@gery_springer
Hidden bodies should not be selectable after performing a Combine/Cut
@mmtomlin
“Project to Surface” on Inclined Place should be more robust
@san_stampings
Decals and Canvases should no longer import rotated and squished
@fritter63
ECAD: Multiple view/monitors shouldn't crash Fusion
@pal_szabo
Just as in prior updates, this isn’t to suggest that these are the only fixes that we've included in the update. The list above are the issues specific to what’s been reported by the Design/Support community; within this update our team has additionally found and fixed well over 100 different bugs and issues.
Still haven’t seen your issue on the list and wondering if/when it's going to get fixed? Don't hesitate to "bump" the original thread that you created, and I'll be happy to chase down the status of your issue!
Thanks again for contributing to what makes the software truly great!
Click here to see release notes from prior updates:
March 2025 - Design
January 2025 - Design
November 2024 - Design
September 2024 - Design
July 2024 - Design
May 2024 - Design
March 2024 - Design
Seth Madore
Risa.Oram
Pan stopped working with middle mouse button click. Am I the only one being impacted by this?
seth.madore
I should add above; the update hasn't gone out yet, but should within the next 24 hours or so (non binding statement, not to be used for any purchase or other financial decisions)
Seth Madore
hajime2MRG3
Thank you seth, decal rotation now looks good.
I will be happy if Decal API also runs in direct modeling mode:
Decal API in direct modeling mode raises "RuntimeError: 2 : InternalValidationError : timelineObj"
